1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: RE: Asyn ModbusTCP communication KO without error messages
To: "'haquin'" <[email protected]>, tech-talk <[email protected]>
Date: Wed, 2 Sep 2015 14:46:41 +0000
Hi Christophe,
Here are some things to look for:
- On vxWorks perhaps a task has been suspended.  Issue the "i" command to look at the status of all of the tasks.
- Perhaps there is a deadlock.  Issue this command several times in a row to see if there is a mutex that is always locked:
epicsMutexShowAll 1
- Perhaps there was a stack overflow.  Issue this command and look for tasks with a margin of 0
checkStack
If you don't find anything there then send us the output of "asynReport 10" on the Read port and Write port.
-----Original Message-----
From: [email protected] [mailto:[email protected]] On Behalf Of haquin
Sent: Wednesday, September 02, 2015 9:00 AM
To: tech-talk
Subject: Asyn ModbusTCP communication KO without error messages
Hi all,
I have a VxWorks IOC (with MVME-CPU using both eth interfaces) communicating with a siemens S7PLC via Asyn/ModbusTCP.
EPICS release 3.14.12.4 Asyn v4.22
After a while  (1 or 2 days), the communication is not working anymore ... but I have no error messages (no timeout nor
disconnection ...).
 From IOC side I a have "Read Multiple Register" function reading the whole modbus table (109 registers) every second
and a "Write Multiple Register" function writing the value of a counter incremented every seconds from record level.
When I activate AsynTrace on IP Port or Read or Write ports there is no messages ...
asynReport on Read port indicates only 1 Read OK
asynReport on Write port indicates 0 Write OK
I can read the PLC register via "modpoll" tool from a Linux PC
I can start a Linux IOC connected to the same PLC
The netstat command on IOC shell tells that the TCP port is established but the Recv-Q is not equal to 0 (12 for example)
What can explain this behavior ?
thanks in advance !
Christophe Haquin
Control and Real Time systems Engineer
+33 231454661 office
+33 231454728 fax
SdA/GIM
GANIL
Bd Henri Becquerel BP 55027
14076 CAEN CEDEX5
Asyn ModbusTCP communication KO without error messages haquin
Prev: Asyn ModbusTCP communication KO without error messages haquin
Next: job openings for neutron-event streaming Tobias Richter
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024
Next: RE: Asyn ModbusTCP communication KO without error messages Mark Rivers
ANJ, 16 Dec 2015 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
