1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: RE: Records for slow control
To: "[email protected]" <[email protected]>, EPICS Tech-Talk <[email protected]>
Date: Wed, 26 Aug 2015 15:20:42 +0000
There are two databases in the synApps std module that demonstrate different ways of doing this with EPICS records:
std/stdApp/Db/timer.*
std/stdApp/op/adl/timer.*
std/stdApp/Db/countDownTmer.*
std/stdApp/op/adl/countDownTimer.*
Tim Mooney ([email protected]) (630)252-5417
Beamline Controls Group (www.aps.anl.gov)
Advanced Photon Source, Argonne National Lab
From: [email protected] [[email protected]] on behalf of [email protected] [[email protected]]
Sent: Wednesday, August 26, 2015 5:09 AM
To: EPICS Tech-Talk
Subject: AW: Records for slow control
Hello,
but I want to increase the value for example every hour. The time have to be variable so I need a calcout timer to count for example every 10 second from 0 to ‎50 and then to increase the value step by step. My problem is how to realise  this with two records. One have to increase +1, then go to the timer record and wait for example one hour set value and again: increase +1, then process timer or counter for slowly periodic scan, set value.
Thanks.
Von: Ralph Lange
Gesendet: Mittwoch, 26. August 2015 11:58
An: EPICS Tech-Talk
Betreff: Re: Records for slow control
On 26/08/2015 11:39, [email protected] wrote:
Hello,
I want to set a value like 200 ampere and increase the current value slowly but how?
I have a timer-record with a PROC field with the option "transition to zero". A second record increase the value every time. Is it possible to create records like this:
• Calcout1 timer: scan every second from 1 to 10
• -» then process Calcout2 (via PROC field, without SCAN field) from 1 to 3
• Calcout2 have to wait, process Calcout1 again...
In the ao record that is setting your value, set the field SCAN to "1 second" (or how often you want to "slowly" update) and the field OROC to the step size that you want to the value to change every time (e.g. 0.1).
No other records needed.
Now, when you write a value like 200 to that record, the output will step up by 0.1 every second. (Or whatever step size and update rate you configured.)
Hope this helps,
~Ralph
AW: Records for slow control info22
Re: Records for slow control info22
Re: Records for slow control Ralph Lange
Prev: RE: Records for slow control Arnold, Ned D.
Next: CSS compile error l123173
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024
Next: AW: Records for slow control info22
ANJ, 16 Dec 2015 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
