On 26/08/2015 11:39, [email protected] wrote:
Hello,
I want
to set a value like 200 ampere and increase the current value
slowly but how?
I have
a timer-record with a PROC field with the option "transition to
zero". A second record increase the value every time. Is it
possible to create records like this:
Calcout1 timer: scan every second from 1 to 10
then process Calcout2 (via PROC field, without SCAN field) from
1 to 3
Calcout2 have to wait, process Calcout1 again...
In the ao record that is setting your value, set the field SCAN to
"1 second" (or how often you want to "slowly" update) and the field
OROC to the step size that you want to the value to change every
time (e.g. 0.1).
No other records needed.
Now, when you write a value like 200 to that record, the output will
step up by 0.1 every second. (Or whatever step size and update rate
you configured.)
Hope this helps,
~Ralph
- AW: Records for slow control info22
- Re: Records for slow control info22
<2015>
<2015>
ANJ, 16 Dec 2015 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
EPICS V4
IRMIS
Talk
Bugs
Documents
Links
Licensing
