1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: MAXv controller limits
To: <[email protected]>
Date: Mon, 1 Jun 2015 14:14:11 -0500
Beginning with EPICS motor module release 6-8-1 there is a workaround for the Limit Mode problem that Phil describes.  The non-asyn EPICS MAXv driver (<motor>/motorApp/OmsSrc/drvMAXv.cc) reads the Limit Mode of each axis at boot-up and if the limit mode is "Off", the driver sets the limit mode to "Hard".
Ron
On 5/29/2015 2:27 PM, Phil Brown wrote:
The OMS MAXv motion controllers with firmware version 1.41 through 1.45 sold before May 26, 2015 will have the limit switch inputs ‘disabled’ by default at power-up.  The limits on MAXv controllers with version 1.41 can be enabled with the LM command.  MAXv controllers with firmware versions newer than 1.41 can use the RDF (Reset Default to Factory) command and then followed by an APP command to store this as the power-up default.  The current version (G) of the MAX FAMILY COMMAND REFERENCE MANUAL indicates that the default state of the limits is enabled, however this is not true for the conditions described above.  The manual we be revised.
All MAXv controllers sold after May 26, 2015 will have the limits enabled at power-up by default.  This condition does not affect the firmware as the power-up state is initially set by the test station when the controllers are initially manufactured.  The test station operation has been modified to leave the MAXv controllers limits in the enabled state by default.
Please contact OMS with any questions or for more information.
Best regards,
Phil
Phillip Brown
OMS Motion, a Pro-Dex company
"The Company in Motion"TM
1-800-707-8111
www.OMSmotion.com
[email protected]
MAXv controller limits Phil Brown
Prev: asynPortDriver deadlock when using asynOctet ambroz . bizjak
Next: EPICSQt version 3.1.0 released Andrew Rhyder
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: MAXv controller limits Phil Brown
Next: asynPortDriver deadlock when using asynOctet ambroz . bizjak
ANJ, 16 Dec 2015 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
