hi, I want to use aSub
record to implement some logic by modifying the myAsubProcess function
in dbSubExample.c file. My aSub record
file is like this: field(OUTA, "PS1:SETI
CPP") *(float*)precord->vala=
value_xxx OUTA filed will
drive a PV in streamdevice driver which communicate to a power supply through
ethernet. My question is: if
I want to measure the time from the beginning of aSub record is processed to
the end of the value is set to power supply correctly? (if the value is set
correctly, the power supply will ack) Thanks a lot for you help. Best wishes
Geyang 2015-05-28
ANJ, 16 Dec 2015 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
