After changing from %i to %d it works! I was not aware of this slight
difference in the format converters.
Thanks for the help!
Am Mittwoch, 8. April 2015, 15:48:55 schrieb Jennings, Guy:
> According to man sscanf, %d might work - it matches a decimal integer -
> whereas %i matches decimal, octal or hexadecimal.
> > On Apr 8, 2015, at 5:30 AM, Jörn Wüstenfeld <[email protected]> wrote:
> > Hello,
> > I have a problem with a device, which returns a value with a fixed length
> > of 3 characters, left padded with zero. If the value is below 100, it is
> > interpreted as an octal value by StreamDevice if I use %i as format. Of
> > course I can use %s and a stringin record, but then I do not have the EGU
> > fioeld available for displaying.
> > Is there a way to handle this in StreamDevice? Or is my only chance to
> > write my own asyn driver for this device?
> > Regards
> > Jörn Wüstenfeld
- StreaDevice formating problem Jörn Wüstenfeld
- Re: StreaDevice formating problem Jennings, Guy
Re: Analog output record (softChannel): How to easily prevent VAL field's clipping within limits Andrew Johnson
Re: Stream device problem with redirection in @mismatch ruzickaj
<2015>
CSS Boy and Signed/Unsigned Int Issue ian.bush
<2015>
