Subject: |
Re: Stream device: how to send waveform of chars without null terminator? |
Dirk Zimoch <[email protected]> |
To: |
Date: |
Thu, 2 Apr 2015 14:04:40 +0200 |
On 01.04.2015 14:03, Dirk Zimoch wrote:
On 01.04.2015 12:07, Isabella Rey wrote:
Hi Ralph,
Yes, but with %s the device receives something like:
load_curve 675892112117108115101461161201160 3870\r\n
You are right. And I think that is a bug.
I found the problem. It only happens during redirection. Without
redirection %s shows the correct behavior. I will send you an update
when I have solved the problem.
(Cause is that dbGet() is called in a way that the array of char is
converted to an array of strings even before StreamDevice starts
printing it.)
Dirk
The null character corresponds to the 0 at the end of the waveform (I've
checked it with small strings)
Isabella
On 1 April 2015 at 10:44, Ralph Lange <[email protected]
<mailto:[email protected]>> wrote:
Have you tried using "%s" for the string output?
~Ralph
On 01/04/2015 10:44, Isabella Rey wrote:
Hi All,
I have a device to which I need to send a file path followed by
a number:
example:
load_curve C:\pulse.txt 3870
The file path is stored in the database as a waveform of chars.
When I run the protocol stream device sends (what I think is) a
null terminator after the file path:
device receives:
load_curve C:\pulse.txt\x00 3870
Is there any way of getting rid of the \x00 terminator?
Below I copy my protocol and the database records.
Cheers,
Isabella
I've defined the protocol in stream device as:
load_curve
out "load_curve %(\$1)c %(\$2)i";
in "%(\$1:\$2)b";
and in the database I have:
record(bo, "DEV:LOAD_CURVE") {
field(DTYP, "stream")
field(OUT, "@my.proto load_curve(DEV:CURVE_FILE, DEV:VPI)
$(PORT)")
record(waveform, "DEV:CURVE_FILE") {
field(DESC, "File path")
field(DTYP, "Soft Channel")
field(NELM, "256")
field(FTVL, "CHAR")
- Stream device: how to send waveform of chars without null terminator? Isabella Rey
- Re: Stream device: how to send waveform of chars without null terminator? Ralph Lange
- Re: Stream device: how to send waveform of chars without null terminator? Isabella Rey
- Re: Stream device: how to send waveform of chars without null terminator? Dirk Zimoch
Re: STAT=SCAN recover - Root issue SOLVED Isabella Rey
New sequencer releases 2.1.19 and 2.2.2 Benjamin Franksen
<2015>
<2015>
ANJ, 16 Dec 2015 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
EPICS V4
IRMIS
Talk
Bugs
Documents
Links
Licensing
