Hi All,
I'm running CSS 3.2.16 in Windows. I have a BOY text input widget that I want to use to write to a waveform of char, called TEST. The waveform is empty at startup. If I type something in the text input, like "abc", I get the following error message in the BOY Console: 2015-03-18 12:04:37 ERROR: Failed to write value to PV TEST from widget Text Input_1. Illegal input : abc java.lang.ArrayIndexOutOfBoundsException: 0 If the waveform is not empty, the string gets updated correctly and there is no error. If I do the same in CSS in my Linux VM, all works fine, even at startup. Is this a bug in the Windows version or am I missing something? Thanks, Isabella
ANJ, 16 Dec 2015 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
