I think you need to put this in a "support" directory.
If you don't have one already, create a new directory (call it something
like "support"), then change to that directory and run 'makeBaseApp.pl
-t support'
You will then find a configure directory and a Makefile. Unzip the s7plc
stuff in the new support directory. s7plc will be in a subdirectory.
On 03/17/2015 01:33 AM, priya tiwari wrote:
Hello sir,
I have downloaded the driver package s7plc.tgz
<http://epics.web.psi.ch/software/s7plc/s7plc.tgz> from PSI for
communicating with Siemens S7 plc 300,but How to use it?
When I make this then got the error there is no
configuration or rule.What is a solution of this problem?
Thanks
Mike Westfall
Gemini Observatory
Colina El Pino S/N, Casilla 603
La Serena, Chile
Tel: +56 51 2205625
- related to PLC driver priya tiwari
RE: Problem with HDF5 plugin for areaDetector Mark Rivers
Text input to char waveform - bug? Isabella Rey
<2015>
<2015>
