Hi Chanaka,
I'm not questioning your choice of an scalcout record. I'm just asking what you want the record to do. For example, what alarm should result from beam_state=='At Injection' while $(DEVICE):State=='ON', and so on.
Tim Mooney ([email protected]) (630)252-5417
Software Services Group (www.aps.anl.gov)
Advanced Photon Source, Argonne National Lab
Sent: Monday, March 02, 2015 1:31 PM
To: Mooney, Tim M.
Cc: [email protected]
Subject: Re: Using sCalcout record
Hi, Tim:
Thank you for the reply.
Why I decided sCalcout? I thought sCalcout is the record that can handle "String" inputs. I have used calcout record previously for such alarm variables. However I never had to handle a "String" as an input. May be I could do without sCalcout.
Thanks, Chanaka.
On Mar 2, 2015, at 2:10 PM, Mooney, Tim M. wrote:
> Hi Chanaka,
> I don't know what you want the scalcout record to do, but you might start with something like this:
> record(scalcout, "calcAlarmState") {
> field(INAA, "beam_state CP")
> field(INBB, "$(DEVICE):State CP")
> field(CALC, ("aa=='At Injection' && bb=='OFF') ? 'WARN' : 'OK'")
> field(OUT, "warning_BeamInjection PP")
> record(bo, "warning_BeamInjection") {
> field(ZNAM, "OK")
> field(ONAM, "WARN"
> field(ZSV, "NO_ALARM")
> field(OSV, "MAJOR")
> From: [email protected] [[email protected]] on behalf of Chanaka De Silva [[email protected]]
> Sent: Monday, March 02, 2015 2:20 AM
> To: [email protected]
> Subject: Using sCalcout record
> Dear, all
> I am in need of developing an alarm variable using the sCalcout record.
> I plan to input two variables that are defined as follows.
> 1.
> grecord(stringout,"beam_state")
> 2.
> record(bi, "$(DEVICE):State")
> field(DESC, "Power Supply On/Off Status")
> field(DTYP, "stream")
> field(INP, "@genesys.proto PSU-getonoff $(IP)")
> field(ZNAM, "OFF")
> field(ONAM, "ON")
> field(ZSV, "MAJOR")
> field(OSV, "NO_ALARM")
> field(PINI, "YES")
> field(FLNK, "$(DEVICE):Limits")
> I decided to use sCalcout since both of these variables output strings.
> For example;
> The first record outputs; "At Injection"
> The second record outputs; "ON"
> I looked up the documentation and could not figure out what is the best approach to write a record to define an alarm variable; let's say
> record(scalcout, warning_BeamInjection){
> I plan to have 1 or 0 assigned to this alarm variable, so that I can set my HIHI alarm to sit at "1".
> Any help is much appreciated.
> Thanks, Chanaka.
- Re: Using sCalcout record Chanaka De Silva
- Using sCalcout record Chanaka De Silva
- RE: Using sCalcout record Mooney, Tim M.
Experience with Nutaq devices Greg Tchilinguirian
<2015>
<2015>
