1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: CSS : Label display precision
To: Amien Crombie <[email protected]>
Date: Thu, 19 Feb 2015 10:06:26 -0200
Hi Amien,
You can try this:
lb.setPropertyValue("text", value.toFixed(2));
HTH,
Hugo
On Thu, Feb 19, 2015 at 9:49 AM, Amien Crombie <[email protected]> wrote:
Hi
Here is the code I'm struggling with:
// _javascript_ file
importPackage(Packages.org.csstudio.opibuilder.scriptUtil);
importPackage(Packages.java.lang);
importPackage(Packages.java.util);
var lb = display.getWidget("Label_5");
var cset  = PVUtil.getDoubleArray(pvs[1]); // Get its double Array values from the 2nd PV waveform
var value = cset[0].getValue();   // just extract first element of array
lb.setPropertyValue("text", value);
My Label_5 displays a huge demical (like '1.7293458101234' etc).
I just need to have a precision of 2 '1.73' etc...
Any way to do this..
Thanks
Amien
CSS : Label display precision Amien Crombie
Prev: CSS : Label display precision Amien Crombie
Next: Looking for Allen Bradley PLC5 Ethernet support Mike Westfall
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024
ANJ, 16 Dec 2015 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
