Hi
Here is the code I'm struggling with:
// _javascript_ file
importPackage(Packages.org.csstudio.opibuilder.scriptUtil);
importPackage(Packages.java.lang);
importPackage(Packages.java.util);
var lb = display.getWidget("Label_5");
var cset = PVUtil.getDoubleArray(pvs[1]); // Get its double
Array values from the 2nd PV waveform
var value = cset[0].getValue(); // just extract first
element of array
lb.setPropertyValue("text", value);
My Label_5 displays a huge demical (like '1.7293458101234' etc).
I just need to have a precision of 2 '1.73' etc...
Any way to do this..
Thanks
Amien
- Re: CSS : Label display precision Hugo Slepicka
RE: Using the EPICS Build/Make system to build kernel modules for linux Williams Jr., Ernest L.
<2015>
Re: CSS - Reverse Scale Amien Crombie
<2015>
ANJ, 16 Dec 2015 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
EPICS V4
IRMIS
Talk
Bugs
Documents
Links
Licensing
