Hi Lewis,
I think the bind() in makeSocket() is failing (as expected) but the subsequent successful call to epicsSocketDestroy() in the same function is clearing the error code, hence when the check is made in repeaterClient::verify () rather than SOCK_EADDRINUSE it is finding 0. One way to fix it might be to change makeSocket() to make a copy of any socket error code and then return that (or 0 on success) rather than true/false
Freddie
> -----Original Message-----
> From: [email protected] [mailto:tech-talk-
> [email protected]] On Behalf Of J. Lewis Muir
> Sent: 09 February 2015 22:13
> To: EPICS Tech-Talk
> Subject: CA Repeater: bind test err was "The operation completed
> successfully. "
> Hello.
> When I run caRepeater.exe from a command prompt in Windows 7 and then
> run camonitor.exe in another command prompt for a PV (hosted on an IOC
> on a different machine) of type DBF_LONG that is updating at about 10
> Hz, the caRepeater.exe process prints the following message on the
> console:
> CA Repeater: bind test err was "The operation completed successfully. "
> The camonitor.exe program seems to continue to run correctly.
> Does anyone know how to fix this?
> I looked briefly at src/ca/repeater.cpp where this error is printed,
> and I changed the fprintf call to also print SOCKERRNO using the format
> "%d", and it prints 0.
> This is using win32-x86 EPICS Base 3.14.12.4 (with the Known Problems
> patches applied) on Windows 7.
> Thank you!
> Lewis
- Re: CA Repeater: bind test err was "The operation completed successfully. " Johnson, Andrew N.
- CA Repeater: bind test err was "The operation completed successfully. " J. Lewis Muir
Re: epicsRingPointer.h error C2664: 'delete' : cannot convert parameter J. Lewis Muir
Re: medm3.1.8 linker problem Dirk Zimoch
<2015>
<2015>
