1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: RE: Alarm annunciation with ALH and other PC based systems
To: Rod Nussbaumer <[email protected]>, epics Techtalk <[email protected]>
Date: Wed, 14 Jan 2015 22:25:30 +0000
Hi Rod,
Background noises and alarm floods are also potential problems, so if alarms are really important, audio needs to be supplemented with visual alarms (i.e., a multi-factor approach needs to be considered).  Relying on audio alarms alone is probably not going to be satisfactory because someone is always going to be adjusting something to suit individual preferences.  Are you doing any alarm filtering?
John Munro
ORNL
-----Original Message-----
From: [email protected] [mailto:[email protected]] On Behalf Of Rod Nussbaumer
Sent: Wednesday, January 14, 2015 4:27 PM
To: epics Techtalk
Subject: Alarm annunciation with ALH and other PC based systems
Hi All:
Sorry that this isn't really an EPICS question, other than the tenuous
connection via Alarm Handler.
The question has been raised here about how to ensure that the audible
alarms from Alarm Handler are always audible. A number of places exist
where this can be disabled. The speakers can become faulty, the
wall-wart commonly used to power the speakers can become disconnected or
faulty, the volume control on the speakers can be turned down, the host
OS software controls can be turned down or muted either through accident
or software fault, audio cables can become faulty, and sound card
hardware can become faulty. Most of these will manifest only in silence.
Has anyone undertaken measures to monitor any of these components in
some way, or implemented hardware which is not subject to the common
frailties of commodity audio equipment used for control room alarms?
Any suggestions cheerfully accepted. Thanks.
Rod Nussbaumer
E-Linac Controls, TRIUMF
Vancouver, Canada.
Alarm annunciation with ALH and other PC based systems Rod Nussbaumer
Prev: industrial barcode reader Pearson, Matthew R.
Next: Open positions at the ALS Bob Gunion
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Alarm annunciation with ALH and other PC based systems Rod Nussbaumer
Next: RE: Alarm annunciation with ALH and other PC based systems ronaldo.mercado
ANJ, 16 Dec 2015 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
