1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Moved 'ether_ip' and Matlab Channel Access 'mca' to GitHub
Date: Fri, 5 Dec 2014 21:12:26 +0000
Hi:
The links from the APS EPICS web site for 'ether_ip' and Matlab Channel Access 'mca' pointed to https://sourceforge.net/projects/epics/.
The SourceForge site used to include wiki pages with basic info, a web interface for browsing the Mercurial-based repo for the ether_ip sources, but they're gone.
I gave up trying to locate or resurrect those, and instead imported both projects to GitHub, since that works well for CSS, AreaDetector and many other projects.
Andrew is updating the links from the APS EPICS web site, so you should still be able the find the stuff as before.
Kay
Prev: Re: Error in Linking a shared library Ralph Lange
Next: Re: Create two channels on same PV name in same CA context? J. Lewis Muir
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Next: envPaths variables Dudley, David
ANJ, 17 Dec 2015 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
