1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: Create two channels on same PV name in same CA context?
To: EPICS Tech-Talk <[email protected]>
Date: Mon, 08 Dec 2014 12:54:17 -0600
On 12/3/14 11:39 AM, Andrew Johnson wrote:
> Hi Lewis,
> On 12/03/2014 11:32 AM, J. Lewis Muir wrote:
>> Is it possible, using the EPICS Base 3.14 CA client library, to
>> create two identical CA channels by calling ca_create_channel() twice
>> on the same PV name in the same CA context?
> Yes, if you do that you will get two different chid objects (which can
> have different puser values). This is what most client programs like
> MEDM will do if you give the same PV name to multiple widgets.
Hi, Andrew.
OK, then I must have a bug in my software.  Let's see here...found it.
Thanks!
Lewis
Create two channels on same PV name in same CA context? J. Lewis Muir
Re: Create two channels on same PV name in same CA context? Andrew Johnson
Prev: Moved 'ether_ip' and Matlab Channel Access 'mca' to GitHub Kasemir, Kay
Next: envPaths variables Dudley, David
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: Create two channels on same PV name in same CA context? Andrew Johnson
Next: Area Detector and Andor Zenon Szalata
ANJ, 17 Dec 2015 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
