On 04/12/2014 14:50, Mark Rivers wrote:
It keeps the module, its tests and examples nicely in the same source
structure (= code repository), which is good as they are usually
developed in parallel.
Where is this documented? I took a quick look in the 3.15.1 Application Developer's Guide and did not find it.
Does the 3.15 makeBaseApp.pl script or some other script have an example of how to use this?
Ehhm... Excellent points, actually.
As far as I recall, creating a directory named *Top in the top level of
your support module is (read: should be) sufficient.
This e.g. "exampleTop" contains the complete embedded (possibly
makeBaseApp-generated) TOP structure, with configure/RELEASE pointing to
"$(TOP)/.." for the support module it is embedded in. Some of the EPICS
V4 modules were the first ones to use this.
Sorry,
~Ralph
- EPICS 3.15.1 Dudley, David
- FW: EPICS 3.15.1 Dudley, David
- RE: FW: EPICS 3.15.1 Dudley, David
- Re: FW: EPICS 3.15.1 Michael Davidsaver
- RE: FW: EPICS 3.15.1 Mooney, Tim M.
- Re: FW: EPICS 3.15.1 Ralph Lange
- RE: FW: EPICS 3.15.1 Mark Rivers
RE: 3.15.1 DB Build Issue Dudley, David
Re: Sorenson SGA DC power supplies Mark Davis
<2014>
<2014>
ANJ, 17 Dec 2015 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
EPICS V4
IRMIS
Talk
Bugs
Documents
Links
Licensing
