1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: EPICS 3.15.1
Date: Tue, 2 Dec 2014 21:22:17 +0000
Should also have included the fact that I have to make a temp change to the CONFIG_BASE configuration file to redefine how dbdExpand is executed.
Slight problem….
Downloaded and compiled fine.
Most of the modules we’re using just needed some minor ‘tweaking’ to get working fine (actually, only about 3-4 needed changes, rest worked with no problems).
HOWEVER-
I’m having problems with the dbdExpand.pl program.  It keeps telling me that I have duplicated records when I try to build my IOCS, with a record name of blank.
I copied the dbExpand program from R3.14.12.4, into the bin directory, renamed it, and built everything with no problem whatsoever.
Any ideas?
Later-
David Dudley
Controls Engineer III
Facility for Rare Isotope Beams
Michigan State University
640 South Shaw Lane
East Lansing, MI 48824, USA
Tel. 517-908-7133
Email: [email protected]
FRIB Logo
Re: EPICS 3.15.1 Andrew Johnson
Prev: Re: Strip Chart widget in EDM Mike Westfall
Next: RE: Using EPICS with Attocube stepper motor Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: Using EPICS with Attocube stepper motor Ana Malagon
Next: Re: EPICS 3.15.1 Andrew Johnson
ANJ, 17 Dec 2015 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
