1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: Possible to close a TCP/IP socket in asyn?
To: Eric Norum <[email protected]>
Date: Thu, 23 Oct 2014 16:32:24 +0100
I didn't but disabling doesn't appear to make a difference, the local port number doesn't change so it is not reconnecting anyway.
On 23/10/14 15:25, Eric Norum wrote:
Do you have autoconnect disabled?
On Oct 23, 2014, at 5:29 AM, Adam Bark <[email protected]> wrote:
Thanks Mark, that certainly clarifies the situation however if I use asynCommonSyncIO::disconnectDevice (the documentation says this calls asynCommon::disconnect) the socket still shows up as "ESTABLISHED" in netstat, at least with 4-22. Am I missing some incantation? I am unclear what should go in drvPvt if I am to use asynCommon::disconnect directly.
Adam.
Eric Norum
[email protected]
Re: Possible to close a TCP/IP socket in asyn? Adam Bark
RE: Possible to close a TCP/IP socket in asyn? Mark Rivers
Re: Possible to close a TCP/IP socket in asyn? Eric Norum
Prev: Re: Possible to close a TCP/IP socket in asyn? Eric Norum
Next: Re: Possible to close a TCP/IP socket in asyn? Adam Bark
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024
ANJ, 17 Dec 2015 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
