On 22/10/14 21:51, Mark Rivers wrote:
Hi Adam,
I have tried disconnecting the asyn port and asynManager's freeAsynUser.
A frequent source of confusion is that the word "disconnect" is used in 2 completely different contexts in asyn. The first is asynManager::disconnect, the second is asynCommon::disconnect.
This is the documentation for pasynManager->disconnect
Disconnect the asynUser from the port,addr to which it is connected via a previous call to connectDevice. The call will fail if the asynUser is queued or locked, or has a callback registered via exceptionCallbackAdd. Note that asynManager:disconnect and asynCommon:disconnect are completely different.
Disconnect from the hardware device or communication path. The queueRequest must specify priority asynQueuePriorityConnect.
You said you "tried disconnecting the asyn port" and that did not work. I suspect that perhaps you called pasynManager::disconnect? All that does is to remove the association of that asynUser structure with a particular port and address. It does not cause the underlying device to be disconnected from asyn, e.g. closing a socket. The reason is simple: there could be many such asynUser structures associated with that port,addr. This provides a way to re-use the asynUser structure to be connected to another port and address.
asynCommon::disconnect causes the port to be disconnected from the device itself, e.g. to close the socket.
____________________________________
Thanks Mark, that certainly clarifies the situation however if I use
asynCommonSyncIO::disconnectDevice (the documentation says this calls
asynCommon::disconnect) the socket still shows up as "ESTABLISHED" in
netstat, at least with 4-22. Am I missing some incantation? I am unclear
what should go in drvPvt if I am to use asynCommon::disconnect directly.
Adam.
- Re: Possible to close a TCP/IP socket in asyn? Eric Norum
- Possible to close a TCP/IP socket in asyn? Adam Bark
- RE: Possible to close a TCP/IP socket in asyn? Mark Rivers
Re: PV monitoring and email reporting tool Johnson, Andrew N.
<2014>
<2014>
