1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: EDM
Date: Mon, 29 Sep 2014 11:18:43 +0530
I am facing another error...
srk@srk:~/epics$ edm
/home/sinclair/edm/sources/libEpics.so: cannot open shared object file: No such file or directory
On Mon, Sep 29, 2014 at 10:13 AM, priya tiwari <[email protected]> wrote:
Hello,
I defined the path in bashrc file like this
export EPICS_CA_AUTO_ADDR_LIST=NO
export EPICS_CA_ADDR_LIST=localhost
export EDMOBJECTS=/home/srk/epics/extensions/src/edm/edmMain
export EDMDATAFILES=/home/srk/epics/extensions/src/edm
export EDMHELPFILES=/home/srk/epics/extensions/src/edm/helpFiles
export EDMPVOBJECTS=/home/srk/epics/extensions/src/edm/edmMain
export EDMFILES=/home/srk/epics/extensions/src/edm
export EPICS_HOME="$HOME/epics"
and i am attaching snapshot of folder please check i am giving right path or not.
Thanks in advance
On Fri, Sep 26, 2014 at 11:25 PM, priya tiwari <[email protected]> wrote:
yes,I am pointing to the right place.
On Fri, Sep 26, 2014 at 12:58 AM, Michael Westfall <[email protected]> wrote:
edmPvObjects is normally in the setup directory — in your case that would be /home/srk/epics/extensions/src/edm/setup/edmPvObjects
Might want to make sure you’re pointing to the right place when you set up the EDM environment variables.
Hello,
          I am facing same problem and EDM doesn't open
 srk@srk:~$ edm
Cannot open pv objects file - /home/srk/epics/extensions/src/edm/edmPvObjects
/libEdmBase.so: cannot open shared object file: No such file or directory
When i run the setup.sh then I am getting this screen.
Re: EDM Michael Westfall
EDM priya tiwari
Re: EDM priya tiwari
Prev: RE: Asyn disconnects, reconnects to serial device server Mark Rivers
Next: Re: EDM Michael Westfall
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: EDM Michael Westfall
ANJ, 17 Dec 2015 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
