1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: EDM
Date: Thu, 25 Sep 2014 19:28:43 +0000
edmPvObjects is normally in the setup directory — in your case that would be /home/srk/epics/extensions/src/edm/setup/edmPvObjects
Might want to make sure you’re pointing to the right place when you set up the EDM environment variables.
Hello,
          I am facing same problem and EDM doesn't open
 srk@srk:~$ edm
Cannot open pv objects file - /home/srk/epics/extensions/src/edm/edmPvObjects
/libEdmBase.so: cannot open shared object file: No such file or directory
When i run the setup.sh then I am getting this screen.
EDM priya tiwari
Re: EDM priya tiwari
Prev: Training and pre-meetings at the upcoming EPICS meeting at SACLAY Dalesio, Leo
Next: Asyn disconnects, reconnects to serial device server jon
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: EDM priya tiwari
Next: Re: EDM priya tiwari
ANJ, 17 Dec 2015 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
