msi is an EPICS extension that converts database files. You can download it from the EPICS Extensions Web page. Put the "epics/extensions"/bin/linux-x86_64 directory in your path.
From: [email protected] [[email protected]] on behalf of Vlad Andrei Rusu [[email protected]]
Sent: Monday, September 22, 2014 6:30 AM
To: [email protected]
Subject: Problem with synApps installing
Hello and thank you in advance for the help.
I am trying to install synApps on my Linux machine and I encountered an error when I used 'make' ( 'make release' ran okay ).
Inflating database from ../ioc.template
msi -I. -I.. -I../O.Common -I../../../db -I/opt/epics/base-3.14.12.3/db ../ioc.template > ioc.tmp
/bin/sh: msi: command not found
make[4]: *** [../O.Common/ioc.db] Error 127
make[4]: Leaving directory `/opt/synApps_5_7/support/devIocStats-3-1-7/iocAdmin/Db/O.linux-x86_64'
make[3]: *** [install.linux-x86_64] Error 2
make[3]: Leaving directory `/opt/synApps_5_7/support/devIocStats-3-1-7/iocAdmin/Db'
make[2]: *** [Db.install] Error 2
make[2]: Leaving directory `/opt/synApps_5_7/support/devIocStats-3-1-7/iocAdmin'
make[1]: *** [iocAdmin.install] Error 2
make[1]: Leaving directory `/opt/synApps_5_7/support/devIocStats-3-1-7'
make: *** [/opt/synApps_5_7/support/devIocStats-3-1-7.install] Error 2
[root@Epics support]#
I think error 127 comes from a missing compiler, but I can't figure it out, is bash trying to use a command 'msi'? but isn't that windows related?
Kind Regards
Rusu Vlad Andrei
T: (+004)0755.052.954
E: [email protected]<mailto:[email protected]>
A: Calea Ferentari 16 Bl.124A Ap.5 Sector 5, Bucharest, Romania
- Problem with synApps installing Vlad Andrei Rusu
build shared library using static library Pavel Maslov
<2014>
<2014>
