Hello and thank you in advance for the help.
I am trying to install synApps on my Linux machine and I encountered an error when I used 'make' ( 'make release' ran okay ). Inflating database from ../ioc.template msi -I. -I.. -I../O.Common -I../../../db -I/opt/epics/base-3.14.12.3/db ../ioc.template > ioc.tmp /bin/sh: msi: command not found make[4]: *** [../O.Common/ioc.db] Error 127 make[4]: Leaving directory `/opt/synApps_5_7/support/devIocStats-3-1-7/iocAdmin/Db/O.linux-x86_64' make[3]: *** [install.linux-x86_64] Error 2 make[3]: Leaving directory `/opt/synApps_5_7/support/devIocStats-3-1-7/iocAdmin/Db' make[2]: *** [Db.install] Error 2 make[2]: Leaving directory `/opt/synApps_5_7/support/devIocStats-3-1-7/iocAdmin' make[1]: *** [iocAdmin.install] Error 2 make[1]: Leaving directory `/opt/synApps_5_7/support/devIocStats-3-1-7' make: *** [/opt/synApps_5_7/support/devIocStats-3-1-7.install] Error 2 [root@Epics support]# I think error 127 comes from a missing compiler, but I can't figure it out, is bash trying to use a command 'msi'? but isn't that windows related? ----------------------------------------------------------------------------- Kind RegardsRusu Vlad Andrei T: (+004)0755.052.954 A: Calea Ferentari 16 Bl.124A Ap.5 Sector 5, Bucharest, Romania
ANJ, 17 Dec 2015 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
