> /bin/sh: msi: command not found
Either add msi to your PATH or add the MSI environment variable to configure/CONFIG_SITE:
MSI=<path-to-your-extensions>/bin/$(EPICS_HOST_ARCH)/msi
Stephanie Allison
> -----Original Message-----
> From: [email protected] [mailto:[email protected]] On Behalf
> Of Vlad Andrei Rusu
> Sent: Thursday, September 11, 2014 6:40 AM
> To: [email protected]
> Subject: msi missing when isntalling synApps
> Hello once again
> We decided to install synApps on Linux and once again, some errors.
> I am getting the following error when trying to "make" synApps, I have downlaoded msi,
> put it extensions/src and 'make' src folder. I also used 'make release' in synApps/support/;
> msi -I. -I.. -I../O.Common -I../../../db -I/opt/epics/base-3.14.12.3/db ../ioc.template >
> ioc.tmp
> make[4]: *** [../O.Common/ioc.db] Error 127
> make[4]: Leaving directory `/opt/synApps_5_7/support/devIocStats-3-1-
> 7/iocAdmin/Db/O.linux-x86_64'
> make[3]: *** [install.linux-x86_64] Error 2
> make[3]: Leaving directory `/opt/synApps_5_7/support/devIocStats-3-1-7/iocAdmin/Db'
> make[2]: *** [Db.install] Error 2
> make[2]: Leaving directory `/opt/synApps_5_7/support/devIocStats-3-1-7/iocAdmin'
> make[1]: *** [iocAdmin.install] Error 2
> make[1]: Leaving directory `/opt/synApps_5_7/support/devIocStats-3-1-7'
> make: *** [/opt/synApps_5_7/support/devIocStats-3-1-7.install] Error 2
> Thank you once again!
> Kind Regards
> Rusu Vlad Andrei
> T: (+004)0755.052.954
> E: [email protected]
> A: Calea Ferentari 16 Bl.124A Ap.5 Sector 5, Bucharest, Romania
- msi missing when isntalling synApps Vlad Andrei Rusu
Re: Keithley 2400 communication Rod Nussbaumer
stream device with Keithley 2410 Alireza Panna
<2014>
Re: msi missing when isntalling synApps Mark Rivers
<2014>
