Hello once again We decided to install synApps on Linux and once again, some errors. I am getting the following error when trying to "make" synApps, I have downlaoded msi, put it extensions/src and 'make' src folder. I also used 'make release' in synApps/support/; msi -I. -I.. -I../O.Common -I../../../db -I/opt/epics/base-3.14.12.3/db ../ioc.template > ioc.tmp /bin/sh: msi: command not found make[4]: *** [../O.Common/ioc.db] Error 127 make[4]: Leaving directory `/opt/synApps_5_7/support/devIocStats-3-1-7/iocAdmin/Db/O.linux-x86_64' make[3]: *** [install.linux-x86_64] Error 2 make[3]: Leaving directory `/opt/synApps_5_7/support/devIocStats-3-1-7/iocAdmin/Db' make[2]: *** [Db.install] Error 2 make[2]: Leaving directory `/opt/synApps_5_7/support/devIocStats-3-1-7/iocAdmin' make[1]: *** [iocAdmin.install] Error 2 make[1]: Leaving directory `/opt/synApps_5_7/support/devIocStats-3-1-7' make: *** [/opt/synApps_5_7/support/devIocStats-3-1-7.install] Error 2 Thank you once again! ----------------------------------------------------------------------------- Kind RegardsRusu Vlad Andrei T: (+004)0755.052.954 A: Calea Ferentari 16 Bl.124A Ap.5 Sector 5, Bucharest, Romania
ANJ, 17 Dec 2015 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
