1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: asyn module installation
To: "Kasemir, Kay" <[email protected]>
Cc: EPICS Tech-Talk <[email protected]>
Date: Wed, 11 Jun 2014 13:40:27 -0700 (PDT)
I am  not creaking test.dbd.
i download asyn module form site and just edit RELEASE for location of base. I haven't include any thing myself.
i just make it and getting error.
Thank you
Vikram
On Wednesday, June 11, 2014 10:27 PM, "Kasemir, Kay" <[email protected]> wrote:
The problem is unlikely in your RELEASE file but in the Makefile for your test lib.
> make[3]: *** No rule to make target `test_registerRecordDeviceDriver.cpp', needed by `test_registerRecordDeviceDriver.o'.  Stop.
means that you should have a test.dbd, either because you have that file, or you have Makefile entries to create it.
From that test.dbd file, the test_registerRecordDeviceDriver.cpp is created.
Compare with the original output of
makeBaseApp.pl -t example test
how it creates a test.dbd etc.
-Kay
On Jun 11, 2014, at 4:09 PM, Vikram Bhagat <[email protected]>
wrote:
> Hi,
>    I have problem for asyn module installation.
> /usr/bin/ar -rc  libtestSupport.a        echoDriver.o addrChangeDriver.o devTestBlock.o interposeInterface.o asynExample.o
> /usr/bin/ranlib libtestSupport.a
> rm -f libtestSupport.so.
> /usr/bin/g++ -o libtestSupport.so. -shared -fPIC -Wl,-hlibtestSupport.so. -L/opt/epics/modules/asyn4-22/lib/linux-x86_64 -L/opt/epics/base-3.15.0.1/lib/linux-x86_64 -Wl,-rpath,/opt/epics/modules/asyn4-22/lib/linux-x86_64 -Wl,-rpath,/opt/epics/base-3.15.0.1/lib/linux-x86_64      -m64              echoDriver.o addrChangeDriver.o devTestBlock.o interposeInterface.o asynExample.o    -lasyn -ldbRecStd -ldbCore -lca -lCom  -lpthread  -lreadline -lm -lrt -ldl -lgcc
> Installing shared library ../../../lib/linux-x86_64/libtestSupport.so.
> Installing library ../../../lib/linux-x86_64/libtestSupport.a
> make[3]: Leaving directory `/opt/epics/modules/asyn4-22/testApp/src/O.linux-x86_64'
> make[2]: *** [install.linux-x86_64] Error 2
> make[2]: Leaving directory `/opt/epics/modules/asyn4-22/testApp/src'
> make[1]: *** [src.install] Error 2
> make[1]: Leaving directory `/opt/epics/modules/asyn4-22/testApp'
> make: *** [testApp.install] Error 2
> I am now able to under stand what is problem to install.
> The configure/RELEASE file set as below
> #RELEASE Location of external products
> #SUPPORT=/corvette/home/epics/devel
> SUPPORT=/opt/epics/modules
> -include $(TOP)/../configure/SUPPORT.$(EPICS_HOST_ARCH)
> #  IPAC is only necessary if support for Greensprings IP488 is required
> #  IPAC release V2-7 or later is required.
> #IPAC=$(SUPPORT)/ipac-2-11
> # SEQ is required for testIPServer
> #SNCSEQ=$(SUPPORT)/seq-2-1-10
> SNCSEQ=$(SUPPORT)/sncseq
> #  EPICS_BASE 3.14.6 or later is required
> LINUX_GPIB=NO
> #EPICS_BASE=/corvette/usr/local/epics/base-3.14.12.3
> EPICS_BASE=/opt/epics/base-3.15.0.1
> -include $(TOP)/../configure/EPICS_BASE.$(EPICS_HOST_ARCH)
> Can you point my mistake?
> With Best Regards
> Vikram
asyn module installation Vikram Bhagat
Prev: asyn module installation Vikram Bhagat
Next: RE: asyn module installation Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024
ANJ, 17 Dec 2015 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
