Hi, I have problem for asyn module installation. /usr/bin/ar -rc libtestSupport.a echoDriver.o addrChangeDriver.o devTestBlock.o interposeInterface.o asynExample.o /usr/bin/ranlib libtestSupport.a rm -f libtestSupport.so. /usr/bin/g++ -o libtestSupport.so. -shared -fPIC -Wl,-hlibtestSupport.so. -L/opt/epics/modules/asyn4-22/lib/linux-x86_64 -L/opt/epics/base-3.15.0.1/lib/linux-x86_64 -Wl,-rpath,/opt/epics/modules/asyn4-22/lib/linux-x86_64 -Wl,-rpath,/opt/epics/base-3.15.0.1/lib/linux-x86_64 -m64 echoDriver.o
addrChangeDriver.o devTestBlock.o interposeInterface.o asynExample.o -lasyn -ldbRecStd -ldbCore -lca -lCom -lpthread -lreadline -lm -lrt -ldl -lgcc Installing shared library ../../../lib/linux-x86_64/libtestSupport.so. Installing library ../../../lib/linux-x86_64/libtestSupport.a make[3]: *** No rule to make target `test_registerRecordDeviceDriver.cpp', needed by `test_registerRecordDeviceDriver.o'. Stop. make[3]: Leaving directory `/opt/epics/modules/asyn4-22/testApp/src/O.linux-x86_64' make[2]: *** [install.linux-x86_64] Error 2 make[2]: Leaving directory `/opt/epics/modules/asyn4-22/testApp/src' make[1]: *** [src.install] Error 2 make[1]: Leaving directory
`/opt/epics/modules/asyn4-22/testApp' make: *** [testApp.install] Error 2 I am now able to under stand what is problem to install. The configure/RELEASE file set as below ############################################## #RELEASE Location of external products #SUPPORT=/corvette/home/epics/devel SUPPORT=/opt/epics/modules -include $(TOP)/../configure/SUPPORT.$(EPICS_HOST_ARCH) # IPAC is only necessary if support for Greensprings IP488 is required # IPAC release V2-7 or later is required. #IPAC=$(SUPPORT)/ipac-2-11 # SEQ is required for testIPServer #SNCSEQ=$(SUPPORT)/seq-2-1-10 SNCSEQ=$(SUPPORT)/sncseq # EPICS_BASE 3.14.6 or later is required LINUX_GPIB=NO #EPICS_BASE=/corvette/usr/local/epics/base-3.14.12.3 EPICS_BASE=/opt/epics/base-3.15.0.1 -include $(TOP)/../configure/EPICS_BASE.$(EPICS_HOST_ARCH) ################################ Can you point my mistake? With Best Regards Vikram
ANJ, 17 Dec 2015 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
