Hi Peter,
Maybe you are using a too old version of StreamDevice?
For most devices, I try to read first 1 byte with ReplyTimeout and then
the rest with ReadTimeout. For serial and socket this works fine. But
GPIB devices must be addressed to talk and then deliver complete
messages. If I now ask for only 1 byte, the GPIB driver reports
overflow. (Unfortunately it does not store the message in some local
input buffer where could pick it up later.)
Thus I have modified StreamDevice to handle GPIB devices differently and
read larger messages. I have changed that behavior quite some time ago.
BTW: At the moment, I am working on a more flexible solution, because
there are other devices, that behave similarly without having a
asynGpibType interface (e.g. usbtmc). Progress is slow however because
of lack of time.
Dirk
On 28.04.2014 16:11, [email protected] wrote:
I’m trying to communicate with a scope using a vxi11 protocol with
stream device & asyn.
I can connect to the device and send output commands which appear to
work, but whenever I try to read a reply I get:
2014/04/28 15:09:21.411 FE-SCOPE-ReadIdent: asynOverflow:
2014/04/28 15:09:21.412 FE-SCOPE-ReadIdent: I/O error from device
2014/04/28 15:09:21.412 FE-SCOPE-ReadIdent: Protocol aborted
Any suggestions for what may be happening?
Pete
Scanned by iCritical.
- RE: asyn vxi11 problem peter.owens
- Re: asyn vxi11 problem Eric Norum
- asyn vxi11 problem peter.owens
Acromag avme9670 LiuP
Re: PCMON segmentation fault Dirk Zimoch
<2014>
<2014>
