1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Acromag avme9670
To: <[email protected]>
Date: Tue, 29 Apr 2014 09:55:14 +0800
With the carrier board AVME9670 and one IP card IP-EP201, I try to run the application of softGlue.
The software version:
EPICS_BASE=/BLC/epics/base3.14.12
SOFTGLUE=$(SUPPORT)/softGlue-2-3
ASYN=$(SUPPORT)/asyn-4-21
IPAC=$(SUPPORT)/ipac-2-11
BUSY=$(SUPPORT)/busy-1-4
The output of st.cmd, the error is remarked in red:
Executing startup script /home/blctrl/Acromag_EP201/iocBoot/iocEP201/st.cmd ...
## Example vxWorks startup file
## The following is needed if your board support package doesn't at boot time
## automatically cd to the directory containing its startup script
cd "/home/blctrl/Acromag_EP201/iocBoot/iocEP201"
value = 0 = 0x0
< cdCommands
startup = "/home/blctrl/Acromag_EP201/iocBoot/iocEP201"
new symbol "startup" added to symbol table.
startup = 0x1ef26cd0: value = 519204080 = 0x1ef26cf0 = startup + 0x20
putenv("ARCH=vxWorks-ppc604_long")
value = 0 = 0x0
putenv("IOC=iocEP201")
value = 0 = 0x0
top = "/home/blctrl/Acromag_EP201"
new symbol "top" added to symbol table.
top = 0x1ef26990: value = 519203792 = 0x1ef26bd0 = top + 0x240
putenv("TOP=/home/blctrl/Acromag_EP201")
value = 0 = 0x0
topbin = "/home/blctrl/Acromag_EP201/bin/vxWorks-ppc604_long"
new symbol "topbin" added to symbol table.
topbin = 0x1ef268c0: value = 519203040 = 0x1ef268e0 = topbin + 0x20
support = "/BLC/epics/support"
new symbol "support" added to symbol table.
support = 0x1ef26840: value = 519202912 = 0x1ef26860 = support + 0x20
putenv("SUPPORT=/BLC/epics/support")
value = 0 = 0x0
softglue = "/BLC/epics/support/softGlue-2-3"
new symbol "softglue" added to symbol table.
softglue = 0x1ef26760: value = 519202688 = 0x1ef26780 = softglue + 0x20
putenv("SOFTGLUE=/BLC/epics/support/softGlue-2-3")
value = 0 = 0x0
asyn = "/BLC/epics/support/asyn-4-21"
new symbol "asyn" added to symbol table.
asyn = 0x1ef26660: value = 519202432 = 0x1ef26680 = asyn + 0x20
putenv("ASYN=/BLC/epics/support/asyn-4-21")
value = 0 = 0x0
asynbin = "/BLC/epics/support/asyn-4-21/bin/vxWorks-ppc604_long"
new symbol "asynbin" added to symbol table.
asynbin = 0x1ef26540: value = 519202144 = 0x1ef26560 = asynbin + 0x20
ipac = "/BLC/epics/support/ipac-2-11"
new symbol "ipac" added to symbol table.
ipac = 0x1ef264c0: value = 519202016 = 0x1ef264e0 = ipac + 0x20
putenv("IPAC=/BLC/epics/support/ipac-2-11")
value = 0 = 0x0
busy = "/BLC/epics/support/busy-1-4"
new symbol "busy" added to symbol table.
busy = 0x1ef263c0: value = 519201760 = 0x1ef263e0 = busy + 0x20
putenv("BUSY=/BLC/epics/support/busy-1-4")
value = 0 = 0x0
epics_base = "/BLC/epics/base"
new symbol "epics_base" added to symbol table.
epics_base = 0x1ef262d0: value = 519201520 = 0x1ef262f0 = epics_base + 0x20
putenv("EPICS_BASE=/BLC/epics/base")
value = 0 = 0x0
epics_basebin = "/BLC/epics/base/bin/vxWorks-ppc604_long"
new symbol "epics_basebin" added to symbol table.
epics_basebin = 0x1ef261e0: value = 519201280 = 0x1ef26200 = epics_basebin + 0x20
#< ../nfsCommands
cd topbin
value = 0 = 0x0
## You may have to change EP201 to something else
## everywhere it appears in this file
ld 0,0, "EP201.munch"
BSP routine sysAtReboot() not found, epicsExit() will not be
called by reboot.  For reduced functionality, call
    rebootHookAdd(epicsExitCallAtExits)
value = 519203312 = 0x1ef269f0 = top + 0x60
cd top
value = 0 = 0x0
dbLoadDatabase "dbd/EP201.dbd"
value = 0 = 0x0
EP201_registerRecordDeviceDriver pdbbase
value = 0 = 0x0
## Load record instances
#dbLoadTemplate "db/user.substitutions"
#dbLoadRecords "db/dbSubExample.db", "user=blctrl"
## Set this to see messages from mySub
#mySubDebug = 1
## Run this to trace the stages of iocInit
#traceIocInit
ipacAddAvme96XX("0x2000,5 A=2,800000")
value = 0 = 0x0
ipacReport(2)
  IP Carrier  0: Acromag AVME-96xx, 4 slots
    C0 S0 : No Module
      ID = 0xf0f02080, I/O = 0xf0f02000, Mem = 0xf0700000
    C0 S1 : No Module
      ID = 0xf0f02180, I/O = 0xf0f02100
    C0 S2 : No Module
      ID = 0xf0f02280, I/O = 0xf0f02200
    C0 S3 : No Module
      ID = 0xf0f02380, I/O = 0xf0f02300
value = 0 = 0x0
drvIP_EP201Debug=1
drvIP_EP201Debug = 0x1ebfe7e4: value = 1 = 0x1
initIP_EP200_FPGA(0, 0, "$(SOFTGLUE)/softGlueApp/Db/SoftGlue_2_2.hex")
initIP_EP200_FPGA: bad carrier or slot
value = -1 = 0xffffffff
cd startup
value = 0 = 0x0
# < softGlue.cmd
iocInit
Starting iocInit
## EPICS R3.14.12.2 $Date: Mon 2011-12-12 14:09:32 -0600$
## EPICS Base built Apr  9 2012
WARNING: OS Clock time was read before being set.
Using 1990-01-02 00:00:00.000000 UTC
value = 0 = 0x0
## Start any sequence programs
#seq &sncExample, "user=blctrl"
Done executing startup script /home/blctrl/Acromag_EP201/iocBoot/iocEP201/st.cmd
Why no module is been found?
No user manual in the package of acromag hardware, and also fail to download the manual.
Without documents, how can I make sure the carrier board has configured successful?
The parameters of ipacAddAvme96XX("0x2000,5 A=2,800000" ) is imitated according to the drvXy9660.c
Any suggest to me is welcome!
LIU Ping
Beamline Contrl Group, SSRF
No. 239 Zhangheng Road, Pudong, Shanghai
Re: Acromag avme9670 Martin L. Smith
Prev: Re: PCMON segmentation fault Ralph Lange
Next: Re: asyn vxi11 problem Dirk Zimoch
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: looking for a part time developer for EPICS kingcomsh
Next: Re: Acromag avme9670 Martin L. Smith
ANJ, 17 Dec 2015 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
