Hi…
I’m having an issue with building synApps on my windows-x64 machine. I am running base3.14.12.4. Here’s the error that I’m getting:
Creating library safeMonitor.lib and object safeMonitor.exp
Generating code
Finished generating code
"preprocessing ../userfunc.st"
cl /C /E /favor:blend /nologo /D__STDC__=0 /D_CRT_SECURE_NO_DEPREC
ATE /D_CRT_NONSTDC_NO_DEPRECATE -I. -I../O.Common -I. -I.. -I../../../include/os
/WIN32 -I../../../include -Ic:\epics\base/include/os/WIN32 -Ic:\epics\base/inclu
de ../userfunc.st > userfunc.i
userfunc.st
"converting userfunc.i"
../../../bin/windows-x64/snc.exe +m -i userfunc.i -o userfunc.c.tmp
perl -MExtUtils::Command -e mv userfunc.c.tmp userfunc.c
cl -c /favor:blend /nologo /D__STDC__=0 /D_CRT_SECURE_NO_DEPRECATE
/D_CRT_NONSTDC_NO_DEPRECATE /Ox /GL /W3 /w44355 /MD -I. -I..\\O.C
ommon -I. -I.. -I..\\..\\..\\include\\os\\WIN32 -I..\\..\\..\\include -Ic:\epics
\base\\include\\os\\WIN32 -Ic:\epics\base\\include userfunc.c
userfunc.c
link -nologo /LTCG /incremental:no /opt:ref /release /MACHINE:X64
-out:userfunc.exe userfunc.obj seqSoftIoc_registerRecordDeviceDriver.obj
testSupport.obj ..\\..\\..\\lib\\windows-x64\\seq.lib ..\\..\\..\\lib\\wi
ndows-x64\\pv.lib c:\epics\base\\lib\\windows-x64\\recIoc.lib c:\epics\base\\l
ib\\windows-x64\\softDevIoc.lib c:\epics\base\\lib\\windows-x64\\miscIoc.lib c
:\epics\base\\lib\\windows-x64\\rsrvIoc.lib c:\epics\base\\lib\\windows-x64\\db
toolsIoc.lib c:\epics\base\\lib\\windows-x64\\asIoc.lib c:\epics\base\\lib\\wi
ndows-x64\\dbIoc.lib c:\epics\base\\lib\\windows-x64\\registryIoc.lib c:\epics
\base\\lib\\windows-x64\\dbStaticIoc.lib c:\epics\base\\lib\\windows-x64\\ca.li
b c:\epics\base\\lib\\windows-x64\\Com.lib
Creating library userfunc.lib and object userfunc.exp
Generating code
"preprocessing ../userfuncEf.st"
de ../userfuncEf.st > userfuncEf.i
userfuncEf.st
"converting userfuncEf.i"
../../../bin/windows-x64/snc.exe +m -i userfuncEf.i -o userfuncEf.c.tmp
perl -MExtUtils::Command -e mv userfuncEf.c.tmp userfuncEf.c
\base\\include\\os\\WIN32 -Ic:\epics\base\\include userfuncEf.c
userfuncEf.c
userfuncEf.c(13) : error C2016: C requires that a struct or union has at least o
ne member
../userfuncEf.st(26) : error C2059: syntax error : '}'
make[4]: *** [userfuncEf.obj] Error 2
make[4]: Leaving directory `c:/epics/synApps_5_7/support/seq-2-1-13/test/validat
e/O.windows-x64'
make[3]: *** [install.windows-x64] Error 2
make[3]: Leaving directory `c:/epics/synApps_5_7/support/seq-2-1-13/test/validat
e'
make[2]: *** [validate.install] Error 2
make[2]: Leaving directory `c:/epics/synApps_5_7/support/seq-2-1-13/test'
make[1]: *** [test.install] Error 2
make[1]: Leaving directory `c:/epics/synApps_5_7/support/seq-2-1-13'
make: *** [c:\epics\synApps_5_7\support/seq-2-1-13.install] Error 2
C:\epics\synApps_5_7\support>
Any hints would be very appreciated…Thanks…
Dave
David Reid
Software Engineer, Behavior
www.alleninstitute.org
