1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: asyn/stream hang on (very long email, sorry in advance)
To: [email protected]
Date: Fri, 25 Apr 2014 11:43:38 +0200
On 23.04.2014 11:51, Mauro Giacchini wrote:
Dear All,
I'm working to make an IOC which has to read strings on rs232;
these strings are continuously sent from a box.
Up to now I'm working just only to
read the this string:
"KS,[counter],[encoder0],[encoder1],[encoder2],[encoder3]"
The IOC works very well to few hours,
after that it's (the communication) hangs-on (??)
Follow the protocol:
InTerminator = LF;
ExtraInput = Ignore;
ReplyTimeout = 1000;
ReadTimeout = 1000;
LockTimeout = 5000;
Note that StreamDevice needs to poll the serial interface for new data when using "I/O Intr". The default for PollPeriod is ReadTimeout, which you set here to 1 second. That may be too long. Have it shorter than the expected repetition rate.
knob_id { in "KS,%d,%*d,%*d,%*d,%*d" ; }
knob_0 { in "KS,%*d,%d,%*d,%*d,%*d" ; }
knob_1 { in "KS,%*d,%*d,%d,%*d,%*d" ; }
knob_2 { in "KS,%*d,%*d,%*d,%d,%*d" ; }
knob_3 { in "KS,%*d,%*d,%*d,%*d,%d" ; }
As Peter suggested, use redirection.
Dirk
multiple threads and ca_attach_context Al Honey
asyn/stream hang on (very long email, sorry in advance) Mauro Giacchini
Prev: Re: Problem building synApps on Windows... Andrew Johnson
Next: Area Detector build issues... David Reid
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: RE: asyn/stream hang on (very long email, sorry in advance) Mark Rivers
Next: Problem building synApps on Windows... David Reid
ANJ, 17 Dec 2015 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
