On 3/17/14 5:29 PM, Pete Jemian wrote:
--- /bin/
+++ /bin/bash
Regarding the environment variable assignment, a cautious approach is to choose whether to define or extend the previous definition. Here is one way in /bin/bash:
if [ "" = "${LD_LIBRARY_PATH}" ]; then
export LD_LIBRARY_PATH=${EPICS_BASE_LIB}
else
export LD_LIBRARY_PATH=${EPICS_BASE_LIB}:${LD_LIBRARY_PATH}
fi
the documentation is now updated: http://prjemian.github.io/epicspi/
Side Note:
To be honest, we don't need the Yoda approach in a shell script.
For the shell enthusiasts: We could simply write
if [ "$LD_LIBRARY_PATH" ]; then
export LD_LIBRARY_PATH=$EPICS_BASE_LIB
else
export LD_LIBRARY_PATH=$EPICS_BASE_LIB:$LD_LIBRARY_PATH
fi
Thanks for the excellent instructions!
I needed another tweek in xxx-5-6/xxxApp/src/Makefile:
This line must be commented out:
xxx_Common_LIBS += ip
I made a shell script, which does everything in one go, see below.
On the long run it may show up on github or so.
#!/bin/sh
BASHRC=~/.bashrc
BASH_ALIAS_EPICS=~/.epics
#Where is the source code of EPICS
HOME_EPICS_APPS=$HOME/../epics/Apps
#Where are the binaries of EPICS
EPICS_ROOT=/usr/local/epics
EPICS_BASE=$EPICS_ROOT/base
EPICS_MODULES=$EPICS_ROOT/modules
#Version of base
EPICS_BASE_VER=3.14.12.3
#Version for ASYN
ASYNVER=asyn4-22
#Version for synApps
SYNAPPSVER=synApps_5_6
#extensions top
EPICS_EXTENSIONS_TOP_VER=extensionsTop_20120904
#msi
EPICS_MSI_VER=msi1-5
export EPICS_ROOT EPICS_BASE EPICS_MODULES EPICS_BASE_VER HOME_EPICS_APPS
export EPICS_EXT=${EPICS_ROOT}/extensions
#apt or yum or port
if uname -a | egrep "CYGWIN|MING" >/dev/null; then
SUDO=
else
SUDO=sudo
fi
APTGET=/bin/false
if type apt-get >/dev/null 2>/dev/null; then
APTGET="$SUDO apt-get install"
fi
if type yum >/dev/null 2>/dev/null; then
APTGET="$SUDO /usr/bin/yum install"
fi
# port (Mac Ports)
if test -x /opt/local/bin/port; then
APTGET="$SUDO port install"
fi
export APTGET
if ! test -d $HOME_EPICS_APPS; then
$SUDO mkdir -p $HOME_EPICS_APPS || {
echo >&2 can not chown $HOME_EPICS_APPS
exit 1
fi
if ! test -w $HOME_EPICS_APPS; then
$SUDO chown "$USER" $HOME_EPICS_APPS || {
exit 1
fi
if test -L $EPICS_ROOT; then
cd /usr/local &&
epicsbaselink=$(readlink epics) &&
#echo epicsbaselink=$epicsbaselink
if test "$epicsbaselink" != "$HOME_EPICS_APPS"; then
echo "$epicsbaselink" != "$HOME_EPICS_APPS" &&
echo $SUDO rm $HOME_EPICS_APPS &&
$SUDO rm $PWD/epics &&
echo $SUDO ln -s $HOME_EPICS_APPS epics &&
$SUDO ln -s $HOME_EPICS_APPS epics || {
echo >&2 can not unlink $HOME_EPICS_APPS
exit 1
fi
else
if test -e $EPICS_ROOT; then
echo >&2 $EPICS_ROOT not a softlink
echo >&2 $EPICS_ROOT please remove it
exit 1
fi
cd /usr/local &&
exit 1
fi
install_re2c()
cd $HOME_EPICS_APPS &&
if ! test -d re2c-code-git; then
git clone git://git.code.sf.net/p/re2c/code-git re2c-code-git.tmp.$$ &&
mv re2c-code-git.tmp.$$ re2c-code-git
fi &&
cd re2c-code-git/re2c &&
./autogen.sh &&
./configure &&
make &&
echo PWD=$PWD $SUDO make install &&
$SUDO make install
if ! test -e baseR${EPICS_BASE_VER}.tar.gz; then
wget http://www.aps.anl.gov/epics/download/base/baseR${EPICS_BASE_VER}.tar.gz -O baseR${EPICS_BASE_VER}.tar.gz.$$ &&
mv baseR${EPICS_BASE_VER}.tar.gz.$$ baseR${EPICS_BASE_VER}.tar.gz || {
echo >&2 can not wget baseR${EPICS_BASE_VER}.tar.gz
exit 1
fi
if ! test -d base-$EPICS_BASE_VER; then
tar xzf baseR${EPICS_BASE_VER}.tar.gz || {
echo >&2 can not tar xzf baseR${EPICS_BASE_VER}.tar.gz
rm -rf base-$EPICS_BASE_VER
exit 1
fi &&
if ! test -L base; then
echo ln -s ./base-${EPICS_BASE_VER} ./base &&
ln -s ./base-${EPICS_BASE_VER} ./base || {
exit 1
fi
) || exit 1
EPICS_HOST_ARCH=$($EPICS_ROOT/base/startup/EpicsHostArch) || {
echo >&2 EPICS_HOST_ARCH failed
exit 1
# here we know the EPICS_HOST_ARCH
EPICS_BASE_BIN=${EPICS_BASE}/bin/$EPICS_HOST_ARCH
EPICS_EXT_BIN=${EPICS_EXT}/bin/$EPICS_HOST_ARCH
PATH=$PATH:$EPICS_BASE_BIN:$EPICS_EXT_BIN
EPICS_EXT_LIB=${EPICS_EXT}/lib/$EPICS_HOST_ARCH
if test "${LD_LIBRARY_PATH}"; then
export LD_LIBRARY_PATH=$LD_LIBRARY_PATH:$EPICS_BASE_LIB
else
export LD_LIBRARY_PATH=$EPICS_EXT_LIB
fi
echo PATH=$PATH
export EPICS_BASE_BIN EPICS_EXT EPICS_EXT_LIB EPICS_EXT_BIN PATH LD_LIBRARY_PATH
############# Fix bashrc (or friends)
if ! grep "$BASH_ALIAS_EPICS" $BASHRC >/dev/null; then
echo updating $BASHRC
cat <<EOF >>$BASHRC
#install-epics.sh
if test -r ${BASH_ALIAS_EPICS}; then
. ${BASH_ALIAS_EPICS}
fi
EOF
fi
if ! test -e ${BASH_ALIAS_EPICS}; then
echo creating en empty ${BASH_ALIAS_EPICS}
touch ${BASH_ALIAS_EPICS}
fi
if ! grep EPICS_EXT_LIB ${BASH_ALIAS_EPICS} >/dev/null; then
echo updating ${BASH_ALIAS_EPICS}
cat >>${BASH_ALIAS_EPICS} <<EOF
export EPICS_ROOT=$EPICS_ROOT
export EPICS_BASE=\$EPICS_ROOT/base
export EPICS_EXT=\${EPICS_ROOT}/extensions
export EPICS_HOST_ARCH=$($EPICS_BASE/startup/EpicsHostArch)
export EPICS_EXT_BIN=${EPICS_EXT}/bin/\$EPICS_HOST_ARCH
export EPICS_EXT_LIB=${EPICS_EXT}/lib/\$EPICS_HOST_ARCH
export EPICS_MODULES=\$EPICS_ROOT/modules
export EPICS_BASE_BIN=\${EPICS_BASE}/bin/\$EPICS_HOST_ARCH
export EPICS_BASE_LIB=\${EPICS_BASE}/lib/\$EPICS_HOST_ARCH
export LD_LIBRARY_PATH=\${EPICS_BASE_LIB}:\$LD_LIBRARY_PATH
if test "\$LD_LIBRARY_PATH"; then
export LD_LIBRARY_PATH=\$LD_LIBRARY_PATH:\$EPICS_BASE_LIB
else
export LD_LIBRARY_PATH=\$EPICS_EXT_LIB
fi
export PATH=\$PATH:\$EPICS_BASE_BIN:\$EPICS_EXT_BIN
EOF
fi
if ! test -e $HOME_EPICS_APPS/base/makeok; then
# We need g++
if ! type g++ >/dev/null 2>/dev/null; then
echo $APTGET g++
$APTGET g++
fi &&
#We need readline
# Mac OS: /usr/include/readline/readline.h
# Linux: /usr/include/readline.h
if ! test -r /usr/include/readline/readline.h; then
test -r /usr/include/readline.h ||
$APTGET readline-devel ||
$APTGET libreadline-dev ||
echo >&2 can not install readline-devel
exit 1
fi
echo make in $HOME_EPICS_APPS/base &&
cd $HOME_EPICS_APPS/base &&
make && touch makeok || {
echo >&2 make failed in $PWD
exit 1
) || exit 1
else
echo The file $HOME_EPICS_APPS/base/makeok exist, skipping make
fi
#Modules
cd $HOME_EPICS_APPS/ &&
if ! test -d modules; then
mkdir modules
fi
) || exit 1
#synApps
if test -n "$SYNAPPSVER"; then
if ! test -e $SYNAPPSVER.tar.gz; then
wget http://www.aps.anl.gov/bcda/synApps/tar/$SYNAPPSVER.tar.gz -O $SYNAPPSVER.tar.gz.$$ &&
mv $SYNAPPSVER.tar.gz.$$ $SYNAPPSVER.tar.gz || {
echo >&2 can not wget $SYNAPPSVER.tar.gz
exit 1
fi &&
if ! test -d $SYNAPPSVER; then
tar xzvf $SYNAPPSVER.tar.gz
fi
echo >&2 failed tar xzvf $SYNAPPSVER.tar.gz in $PWD
exit 1
cd $HOME_EPICS_APPS/synApps_5_6/support/configure &&
if ! test -e RELEASE.orig; then
cp -v RELEASE RELEASE.orig || exit 1
fi &&
sed <RELEASE.orig >/tmp/$$ \
-e "s!^SUPPORT=.*!SUPPORT=$EPICS_ROOT/synApps_5_6/support!" \
-e "s!^EPICS_BASE=.*!EPICS_BASE=$EPICS_ROOT/base!" &&
mv -fv /tmp/$$ RELEASE
echo >&2 failed RELEASE in $PWD
exit 1
mkdir -p orig || {
echo >&2 failed mkdir -p orig in $PWD
exit 1
for f in EPICS_BASE.cygwin-x86 EPICS_BASE.linux-x86 EPICS_BASE.linux-x86_64 EPICS_BASE.win32-x86 EPICS_BASE.windows-x64 SUPPORT.cygwin-x86 SUPPORT.linux-x86 SUPPORT.linux-x86_64 SUPPORT.win32-x86 SUPPORT.windows-x64; do
if test -e "$f"; then
mv -v "$f" $PWD/orig/ || {
echo >&2 failed mv "$f" orig/ in $PWD
exit 1
fi
done
echo cd $HOME_EPICS_APPS/synApps_5_6/support &&
if ! test -e makereleaseok; then
make release && touch makereleaseok || {
echo >&2 failed make release in $PWD
exit 1
else
echo The file $PWD/makereleaseok exist, skipping make release
fi
if ! test -e Makefile.orig; then
cp -v Makefile Makefile.orig || exit 1
fi &&
cp -v Makefile.orig Makefile &&
for mod in ALLEN_BRADLEY DAC128V IP330 IPUNIDIG LOVE IP VAC SOFTGLUE QUADEM DELAYGEN CAMAC VME AREA_DETECTOR DXP; do
echo removing $mod in $PWD/Makefile &&
sed -e "s/ $mod / /g" -e "s/ $mod\$/ /g" <Makefile >Makefile.tmp.$$ &&
! diff Makefile Makefile.tmp.$$ >/dev/null &&
mv -f Makefile.tmp.$$ Makefile ||{
echo >&2 failed removing $mod in $PWD
exit 1
done &&
# Remove AREA_DETECTOR and IP from RELEASE
cd xxx-5-6/configure &&
fi &&
sed <RELEASE.orig >RELEASE.tmp.$$ \
-e "s!^AREA_DETECTOR!#AREA_DETECTOR!" \
-e "s!^IP=!#IP=!" &&
mv -fv RELEASE.tmp.$$ RELEASE
# Remove AREA_DETECTOR and IP from dbd
cd xxx-5-6/xxxApp/src &&
if ! test -e xxxCommonInclude.dbd.orig; then
cp -v xxxCommonInclude.dbd xxxCommonInclude.dbd.orig || exit 1
fi &&
sed <xxxCommonInclude.dbd.orig >xxxCommonInclude.dbd.tmp.$$ \
-e "s!\(include.*ipSupport.dbd\)!#\1!" &&
mv -fv xxxCommonInclude.dbd.tmp.$$ xxxCommonInclude.dbd
# Remove AREA_DETECTOR related modules from Makefile
fi &&
cp Makefile.orig Makefile &&
for mod in ADSupport NDPlugin simDetector netCDF dxp "xxx_Common_LIBS += ip"; do
sed -e "s/\(.*$mod.*\)/#XXX Removed by install-epics.sh XXX \1/g" <Makefile >Makefile.tmp.$$ &&
mv -f $PWD/Makefile.tmp.$$ $PWD/Makefile ||{
exit 1
done
echo >&2 failed in $PWD
exit 1
cd $HOME_EPICS_APPS/modules &&
if ! test -d motor; then
ln -sv ../synApps_5_6/support/motor-6-7/ motor || {
echo >&2 Can not ln -sv ../synApps_5_6/support/motor-6-7/ motor
exit 1
fi
exit 1
if test "$EPICS_EXTENSIONS_TOP_VER"; then
if ! test -e $EPICS_EXTENSIONS_TOP_VER.tar.gz; then
echo installing $EPICS_EXTENSIONS_TOP_VER &&
wget http://www.aps.anl.gov/epics/download/extensions/$EPICS_EXTENSIONS_TOP_VER.tar.gz -O $EPICS_EXTENSIONS_TOP_VER.tar.gz.$$ &&
mv $EPICS_EXTENSIONS_TOP_VER.tar.gz.$$ $EPICS_EXTENSIONS_TOP_VER.tar.gz || {
echo >&2 can not wget $EPICS_EXTENSIONS_TOP_VER.tar.gz
exit 1
fi
if ! test -d ${EPICS_EXTENSIONS_TOP_VER}; then
tar xzf $EPICS_EXTENSIONS_TOP_VER.tar.gz
fi
fi &&
if ! type re2c >/dev/null 2>/dev/null; then
echo $APTGET re2c
$APTGET re2c || install_re2c
fi &&
if test "$EPICS_MSI_VER"; then
if ! test -e $EPICS_MSI_VER.tar.gz; then
echo installing $EPICS_MSI_VER &&
wget http://www.aps.anl.gov/epics/download/extensions/$EPICS_MSI_VER.tar.gz -O $EPICS_MSI_VER.tar.gz.$$ &&
mv $EPICS_MSI_VER.tar.gz.$$ $EPICS_MSI_VER.tar.gz || {
echo >&2 can not wget $EPICS_MSI_VER.tar.gz
exit 1
fi &&
if ! test -e extensions/src/$EPICS_MSI_VER/makeok; then
mkdir -p extensions/src &&
cd extensions/src &&
tar xzf ../../$EPICS_MSI_VER.tar.gz &&
cd $EPICS_MSI_VER &&
exit 1
echo >&2 msi failed in $PWD
exit 1
else
echo The file extensions/src/$EPICS_MSI_VER/makeok exist, skipping make
fi
fi &&
if ! test -e makeok; then
make release || {
echo >&2 PWD=$PWD failed make release
exit 1
make rebuild && touch makeok || {
echo >&2 PWD=$PWD failed make rebuild
echo >&2 PATH=$PATH
exit 1
else
echo The file $PWD/makeok exist, skipping make
fi
echo >&2 failed $SYNAPPSVER PWD=$PWD PATH=$PATH
exit 1
else
echo SYNAPPSVER not defined, skipping synApps
fi
if test -n "$ASYNVER"; then
if ! test -d asyn; then
ln -sv ../asyn4-22/ asyn || {
echo >&2 Can not ln -sv ../asyn4-22/ asyn
exit 1
fi
if ! test -e $ASYNVER.tar.gz; then
wget http://www.aps.anl.gov/epics/download/modules/$ASYNVER.tar.gz -O $ASYNVER.tar.gz.$$ &&
mv $ASYNVER.tar.gz.$$ $ASYNVER.tar.gz || {
echo >&2 can not wget $ASYNVER.tar.gz
exit 1
fi
if ! test -d $ASYNVER; then
tar xzvf $ASYNVER.tar.gz
fi
cd $HOME_EPICS_APPS/$ASYNVER/configure && {
fi
-e "s!^EPICS_BASE=.*!EPICS_BASE=$EPICS_ROOT/base!" \
-e 's!^IPAC=!#IPAC=!' \
-e 's!^SNCSEQ=!#SNCSEQ=!' &&
mv -vf /tmp/$$ RELEASE
if ! test -e $HOME_EPICS_APPS/$ASYNVER/makeok; then
cd $HOME_EPICS_APPS/$ASYNVER &&
exit 1
else
echo The file $HOME_EPICS_APPS/$ASYNVER/makeok exist, skipping make
fi
echo >&2 failed $ASYNVER
exit 1
else
echo ASYNVER not defined, skipping asyn
fi
- Re: Installing EPICS on the Raspberry Pi Torsten Bögershausen
- Installing EPICS on the Raspberry Pi Pete Jemian
- Re: Installing EPICS on the Raspberry Pi Pete Jemian
Re: build question Stephen Beckwith
Re: Multiple IOCs on one Linux host Ralph Lange
<2014>
<2014>
