1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: 3.14.12 build problem with vxWorks 6.9
To: "<[email protected]>" <[email protected]>
Cc: EPICS tech-talk <[email protected]>
Date: Sun, 23 Mar 2014 19:23:48 +0000
Hi Philip,
I forget if we ever worked out what the problem was in that report, but please try building for the vxWorks-ppc32 target instead; this produces binaries that can be loaded on almost every 32-bit PowerPC VxWorks 6.x target and is what we use here at the APS (the exceptions are the MVME3100 and possibly 4100 boards which need the -ppc32sf target for soft-float instructions). We keep the older targets for VxWorks 5.5.x builds of the same version of Base so our IOCs can be upgraded in stages.
HTH,
- Andrew
Sent from my iPad
> On Mar 23, 2014, at 12:52 PM, "Philip Taylor" <[email protected]> wrote:
> I am currently using an evaluation license version of VxWorks 6.9 and experienced
> the same compiler fault that was reported in core-talk back in 2010:
> http://www.aps.anl.gov/epics/core-talk/2010/msg00172.php
> I am trying to cross-compile EPICS R3.14.12.4 using the Wind River VxWorks 6.9 supplied compiler for a ppc604_long target running on a linux-x86_64 host (CentOS 6.1 64-bit).
> Has anyone also seen this with 6.9 and do you know whether WRS have issued a fix? I had hoped it would have been fixed in 6.9. I have been in touch with Wind River UK but they have not been able to help me so far.
> The work-round described previously appears to work (switching off optimization),
> Regards,
> Philip
> Philip Taylor                       email : [email protected]
> Observatory Sciences Ltd.           Web   : http://www.observatorysciences.co.uk
> Brighton Media Centre               Phone : (UK)+(0)1223-655603
> 21-22 Old Steine                    Mobile : 07913-720806
> BRIGHTON.
> BN1 1EL
> U.K.
3.14.12 build problem with vxWorks 6.9 Philip Taylor
Prev: 3.14.12 build problem with vxWorks 6.9 Philip Taylor
Next: Re: VxWorks VME Ctrl-X vs. Power Cycle Jeong Han Lee
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Next: How to check if IOC is connected or not? Ganesh Jangir
ANJ, 17 Dec 2015 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
