I have multiple IOC(say 4) on 4 linux (Fedora, 64bit) machines over network. Each IOC also have running Sequencer program. Sequencer of each IOC need to be aware of every IOC if they are running or not/ machine connected or not, before doing some task. How to do this? I tried using CALC Record. Its 4 INP fields gets some particular value from four different IOC and calculate some new value,By interpreting this value Sequencer come to know about the connected IOC. The problem is that , in case of some disconnection of IOC , its INP fields picking old values. And CALC record gives same value in each case. Is this right approach for many IOCs? How to make INP fields, to give different value in case of disconnection of some IOC. Second, I also tried using pvConnected() function of sequencer. But it starts giving error messages incase of disconnection, before checking it. ___________________________________________________ I am using Epics base-3.14.12.3 Sequencer seq-2.1.16 OS: Linux Fedora 19 64bit I have following settings. export EPICS_ROOT=/home/ganesh/epics export EPICS_HOST_ARCH=linux-x86_64 export EPICS_BASE=$EPICS_ROOT/base-3.14.12.3 export EPICS_EXTENSIONS=$EPICS_ROOT/extensions export EPICS_CA_ADDR_LIST="192.168.8.2 192.168.8.3 192.168.8.4 192.168.8.5" export MOTIF_LIB=/usr/lib64/ export SEQ=$EPICS_ROOT/extensions/seq-2.1.16 export PATH=/sbin:/bin:/usr/sbin:/usr/bin:$file:$EPICS_ROOT/base-3.14.12.3/bin/linux-x86_64:/bin/linux-x86_64 export LD_LIBRARY_PATH=$LD_LIBRARY_PATH:$EPICS_BASE/lib/$EPICS_HOST_ARCH:$EPICS_EXTENSIONS/lib/$EPICS_HOST_ARCH __________________________________________________________________ Best Regards Ganesh =====-----=====-----=====
ANJ, 17 Dec 2015 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
