1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: Battling to start archive.engine on Postgresql db
To: "Kasemir, Kay" <[email protected]>, tech-talk <[email protected]>
Date: Wed, 05 Mar 2014 10:40:00 +0200
Hi Kay,
Many thanks for the enlightenment, especially on the advice of leaving the source files intact. I have created the settings.ini file pointing to the use of the postgresql db and adding to addr_list for our subnet and it works fine.
There were two things I did wrong:
1. I had commented out the schema line:
org.csstudio.archive.rdb/schema= from file plugin_customization.ini of org.csstudio.archive.engine I had read this some where, that this needed to be removed as it was only needed for the oracle db, can't find the article right now! 2. I also didn't spot that the create users archive and report and the granting of rights is all commented out of the postgres_schema.txt.
    This is a bit different to the mysql_schema.txt.
Thanks for the help,
Ivan
On 04/03/2014 16:14, Kasemir, Kay wrote:
Hi:
On Mar 3, 2014, at 5:17 PM, Ivan Kohler <[email protected]> wrote:
I managed to start CSS archive.engine on a MySQL db,
Good, so at least something is working.
In Eclipse I edited:
   plugin_customization.ini file
org.csstudio.archive.rdb/url=jdbc:postgresql://localhost:5432/archive
and
org.csstudio.archive.engine.rdb
   preferences.ini file
     # Postgresql example
url=jdbc:postgresql://localhost/archive?rewriteBatchedStatements=true
You should leave the "preferences.ini" files unchanged. They contain the defaults and explanation of available settings.
To specify what you actually want to use, you _could_ edit the plugin_customization.ini in the archive engine sources, but better would be to not edit any sources and instead provide the path to _your_ plugin_customization.ini file on the command-line:
  ArchiveEngine -pluginCustomization /path/to/my/settings.ini -engine Demo ….
See also "Hierarchical Preferences" in the CSS Guide, http://cs-studio.sourceforge.net/docbook/ch06.html
Caused by: java.lang.NullPointerException
     at
org.csstudio.archive.rdb.RDBArchivePreferences.getSchema(RDBArchivePreferences.java:37)
Strange.
For Postgres you should configure the "schema" to be empty, just as you did with MySQL.
So your settings.ini would contain:
# Set schema to empty
The error message suggests that the 'schema' is not defined at all, which could only happen if you deleted it from the org.csstudio.archive.rdb/preferences.ini as well as org.csstudio.archive.engine/plugin_customization.ini.
Kay
Battling to start archive.engine on Postgresql db Ivan Kohler
Re: Battling to start archive.engine on Postgresql db Kasemir, Kay
Prev: CSS BEAST alarm hierarchy Xinyu.Wu
Next: Re: CSS BEAST alarm hierarchy Kasemir, Kay
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: Battling to start archive.engine on Postgresql db Kasemir, Kay
Next: RE: Battling to start archive.engine on Postgresql db ivan
ANJ, 17 Dec 2015 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
