Hi All,
I seem to have found the problem.
It is related to user rights, when I changed
from
org.csstudio.archive.rdb/user=archive
org.csstudio.archive.rdb/password=$archive
to
org.csstudio.archive.rdb/user=postgres
org.csstudio.archive.rdb/password=<my_password>
in
org.csstudio.archive.engine , 'plugin_customization.ini' file
then the archive.engine started
I was a little surprised as I thought user archive was created in
the postgres_schema.txt.
I am a bit new to postgresql to know what I should do about it.
Ivan Kohler,
iThemba Labs, South Africa
-------- Original Message --------
Hi All,
I managed to start CSS archive.engine on a MySQL db, now I am trying to
get it started on a Postgresql db.
I am on a PC running Ubuntu 1204 using:
Java: JDK SE Dev Kit 7.51
Eclipse fro RCP and RAP Developers ver 1.4.2
SNS Sources 3.2.14
I installed postgresql 9.1 and loaded the schema with:
sudo -u postgres psql <
~/css/sources/org.csstudio.archive.rdb/dbd/postgres_schema.txt
So smpl_eng has the Demo engine in it:
1, Demo, Demo Engine, http://localhost:4812
I edited postgresql's pg_hba.conf file
host all all 127.0.0.1/32 md5
host all all 10.0.0.1/24 md5 #
Added this line
In Eclipse I edited:
plugin_customization.ini file
org.csstudio.archive.rdb/url=""
and
org.csstudio.archive.engine.rdb
preferences.ini file
# Postgresql example
url=""
Before Launching the ArchiveEngine.product I added
Program Arguments using the 'Launching' tab
-engine Demo
-port 4812
On Launching I got the following in the Eclipse Console:
2014-03-03 23:11:01.753 INFO [Thread 1]
org.csstudio.archive.engine.Application (start) - Archive Engine
3.2.14.qualifier
2014-03-03 23:11:01.896 INFO [Thread 1]
org.csstudio.archive.engine.server.EngineServer (<init>) - Engine HTTP
Server on http://localhost:4812/main
2014-03-03 23:11:01.897 INFO [Thread 1]
org.csstudio.archive.engine.Application (start) - Reading configuration
'Demo'
2014-03-03 23:11:01.939 SEVERE [Thread 1]
org.csstudio.archive.engine.Application (start) - Cannot read configuration
org.eclipse.core.runtime.CoreException: Plug-in
"org.csstudio.archive.config.rdb" was unable to instantiate class
"org.csstudio.archive.config.rdb.RDBArchiveConfig".
at
org.eclipse.core.internal.registry.osgi.RegistryStrategyOSGI.throwException(RegistryStrategyOSGI.java:194)
at
org.eclipse.core.internal.registry.osgi.RegistryStrategyOSGI.createExecutableExtension(RegistryStrategyOSGI.java:186)
at
org.eclipse.core.internal.registry.ExtensionRegistry.createExecutableExtension(ExtensionRegistry.java:905)
at
org.eclipse.core.internal.registry.ConfigurationElement.createExecutableExtension(ConfigurationElement.java:243)
at
org.eclipse.core.internal.registry.ConfigurationElementHandle.createExecutableExtension(ConfigurationElementHandle.java:55)
at
org.csstudio.archive.config.ArchiveConfigFactory.getArchiveConfig(ArchiveConfigFactory.java:37)
at org.csstudio.archive.engine.Application.start(Application.java:164)
at
org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:196)
at
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:110)
at
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:79)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:344)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:179)
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at
sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:57)
at
sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
at java.lang.reflect.Method.invoke(Method.java:606)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:622)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:577)
at org.eclipse.equinox.launcher.Main.run(Main.java:1410)
at org.eclipse.equinox.launcher.Main.main(Main.java:1386)
Caused by: java.lang.NullPointerException
at
org.csstudio.archive.rdb.RDBArchivePreferences.getSchema(RDBArchivePreferences.java:37)
at
org.csstudio.archive.config.rdb.RDBArchiveConfig.<init>(RDBArchiveConfig.java:66)
at sun.reflect.NativeConstructorAccessorImpl.newInstance0(Native
Method)
at
sun.reflect.NativeConstructorAccessorImpl.newInstance(NativeConstructorAccessorImpl.java:57)
at
sun.reflect.DelegatingConstructorAccessorImpl.newInstance(DelegatingConstructorAccessorImpl.java:45)
at java.lang.reflect.Constructor.newInstance(Constructor.java:526)
at java.lang.Class.newInstance(Class.java:374)
at
org.eclipse.core.internal.registry.osgi.RegistryStrategyOSGI.createExecutableExtension(RegistryStrategyOSGI.java:184)
... 18 more
Any comments would be greatly appreciated.
Best Regards,
Ivan Kohler
iThemba LABS,
South Africa
- Battling to start archive.engine on Postgresql db Ivan Kohler
#personal#Fw: Error in feching PV from CSS Swati Soni2
Re: #personal#Fw: Error in feching PV from CSS David Michel
<2014>
Re: Battling to start archive.engine on Postgresql db Ivan Kohler
EPICS RE: epics on beaglebone Keith Parker
<2014>
ANJ, 17 Dec 2015 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
EPICS V4
IRMIS
Talk
Bugs
Documents
Links
Licensing
