1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: RE: Store long strings in EPICS record.
To: "'Zelazny, Michael Stanley'" <[email protected]>, Ganesh Jangir <[email protected]>, "[email protected]" <[email protected]>
Cc: controls-software <[email protected]>
Date: Tue, 25 Feb 2014 15:02:12 +0000
The option is -S, i.e. uppercase.
corvette:dxp/dxpApp/src>caget -help
Usage: caget [options] <PV name> ...
  -h: Help: Print this message
Channel Access options:
  -w <sec>: Wait time, specifies CA timeout, default is 1.000000 second(s)
  -c: Asynchronous get (use ca_get_callback and wait for completion)
  -p <prio>: CA priority (0-99, default 0=lowest)
Format options:
      Default output format is "name value"
  -t: Terse mode - print only value, without name
  -a: Wide mode "name timestamp value stat sevr" (read PVs as DBR_TIME_xxx)
  -d <type>: Request specific dbr type; use string (DBR_ prefix may be omitted)
      or number of one of the following types:
 DBR_STRING     0  DBR_STS_FLOAT    9  DBR_TIME_LONG   19  DBR_CTRL_SHORT    29
 DBR_INT        1  DBR_STS_ENUM    10  DBR_TIME_DOUBLE 20  DBR_CTRL_INT      29
 DBR_SHORT      1  DBR_STS_CHAR    11  DBR_GR_STRING   21  DBR_CTRL_FLOAT    30
 DBR_FLOAT      2  DBR_STS_LONG    12  DBR_GR_SHORT    22  DBR_CTRL_ENUM     31
 DBR_ENUM       3  DBR_STS_DOUBLE  13  DBR_GR_INT      22  DBR_CTRL_CHAR     32
 DBR_CHAR       4  DBR_TIME_STRING 14  DBR_GR_FLOAT    23  DBR_CTRL_LONG     33
 DBR_LONG       5  DBR_TIME_INT    15  DBR_GR_ENUM     24  DBR_CTRL_DOUBLE   34
 DBR_DOUBLE     6  DBR_TIME_SHORT  15  DBR_GR_CHAR     25  DBR_STSACK_STRING 37
 DBR_STS_STRING 7  DBR_TIME_FLOAT  16  DBR_GR_LONG     26  DBR_CLASS_NAME    38
 DBR_STS_SHORT  8  DBR_TIME_ENUM   17  DBR_GR_DOUBLE   27
 DBR_STS_INT    8  DBR_TIME_CHAR   18  DBR_CTRL_STRING 28
Enum format:
  -n: Print DBF_ENUM value as number (default is enum string)
Arrays: Value format: print number of requested values, then list of values
  Default:    Print all values
  -# <count>: Print first <count> elements of an array
  -S:         Print array of char as a string (long string)
Floating point type format:
  Default: Use %g format
  -e <nr>: Use %e format, with a precision of <nr> digits
  -f <nr>: Use %f format, with a precision of <nr> digits
  -g <nr>: Use %g format, with a precision of <nr> digits
  -s:      Get value as string (honors server-side precision)
  -lx:     Round to long integer and print as hex number
  -lo:     Round to long integer and print as octal number
  -lb:     Round to long integer and print as binary number
Integer number format:
  Default: Print as decimal number
  -0x: Print as hex number
  -0o: Print as octal number
  -0b: Print as binary number
Alternate output field separator:
  -F <ofs>: Use <ofs> as an alternate output field separator
Example: caget -a -f8 my_channel another_channel
  (uses wide output format, doubles are printed as %f with precision of 8)
But it does not seem to exist in your version, I don't know when it was added.
-----Original Message-----
From: Zelazny, Michael Stanley [mailto:[email protected]]
Sent: Tuesday, February 25, 2014 8:43 AM
To: Mark Rivers; Ganesh Jangir; [email protected]
What version of caget do I need to get this behavior?
~/zelazny>caget -s SIOC:SYS0:ML00:CA001
SIOC:SYS0:ML00:CA001 1000 84 'T' 104 'h' 105 'i' 115 's' 32 ' ' 105 'i' 115 's' 32 ' ' 97 'a' 32 ' ' 118 'v' 101 'e' 114 'r' 121 'y' 32 ' ' 108 'l' 111 'o' 110 'n' 103 'g' 32 ' ' 115 's' 116 't' 114 'r' 105 'i' 110 'n' 103 'g' 46 '.' 32 ' ' 73 'I' 116 't' 39 ''' 115 's' 32 ' ' 49 '1' 48 '0' 48 '0' 48 '0' 32 ' ' 99 'c' 104 'h' 97 'a' 114 'r' 97 'a' 99 'c' 116 't' 101 'e' 114 'r' 115 's' 32 ' ' 108 'l' 111 'o' 110 'n' 103 'g' 46 '.' 32 ' ' 69 'E' 110 'n' 106 'j' 111 'o' 121 'y' 33 '!' 32 ' ' 102 'f' 114 'r' 111 'o' 109 'm' 32 ' ' 77 'M' 97 'a' 116 't' 108 'l' 97 'a' 98 'b' 32 ' ' 117 'u' 115 's' 101 'e' 32 ' ' 100 'd' 111 'o' 117 'u' 98 'b' 108 'l' 101 'e' 40 '(' 105 'i' 110 'n' 116 't' 56 '8' 40 '(' 39 ''' 89 'Y' 111 'o' 117 'u' 114 'r' 32 ' ' 83 'S' 84 'T' 82 'R' 39 ''' 41 ')' 32 ' ' 32 ' ' 116 't' 111 'o' 32 ' ' 108 'l' 99 'c' 97 'a' 80 'P' 117 'u' 116 't' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' !
 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 3!
 2 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32!
  ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 !
 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 '!
  ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' !
 ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' ' 32 ' '!
~/zelazny>caget -h
  -w <sec>: Wait time, specifies longer CA timeout, default is 1.000000 second
  -c: Asynchronous get (use ca_get_callback instead of ca_get)
Format options:
Enum format:
  -s:      Get value as string (may honour server-side precision)
~/zelazny>  ~/zelazny>cainfo SIOC:SYS0:ML00:CA001
    State:         connected
    Host:          <node-name-removed>.slac.stanford.edu:42312
    Access:        read, write
    Data type:     DBR_CHAR (native: DBF_CHAR)
    Element count: 1000
~/zelazny>
From: [email protected] [[email protected]] On Behalf Of Mark Rivers [[email protected]]
Sent: Tuesday, February 25, 2014 3:49 AM
To: Ganesh Jangir; [email protected]
You cannot store a long string in a stringin record.
However, you can store a long string in a waveform record with FTVL=CHAR.  caget, medm and other clients know how to display this correctly.
Here is an example:
corvette:~>cainfo GSE-PIL1:cam1:FullFileName_RBV
    State:            connected
    Host:             164.54.160.161:5064
    Access:           read, write
    Native data type: DBF_CHAR
    Request type:     DBR_CHAR
    Element count:    256
corvette:~>caget -S GSE-PIL1:cam1:FullFileName_RBV
GSE-PIL1:cam1:FullFileName_RBV /cars5/Data/gpd_user/data/idc/2014/run1/eng/testing/images/testing_1/S045/stubbs_test_1002.tif
From: [email protected] [[email protected]] on behalf of Ganesh Jangir [[email protected]]
Sent: Tuesday, February 25, 2014 5:32 AM
To: [email protected]
Subject: Store long strings in EPICS record.
Dear All,
How to store array of strings, char arr[64][64]  or a long string of size (65x64) byte in to EPICS record.
Its needed to communicate via Channel Access to Sequencer.What are the suitable ways to achieve this.
How to increase size of record type stringIn.
Thanks and Regards
Ganesh Jangir
Notice: The information contained in this e-mail
message and/or attachments to it may contain
confidential or privileged information. If you are
not the intended recipient, any dissemination, use,
review, distribution, printing or copying of the
information contained in this e-mail message
and/or attachments to it are strictly prohibited. If
you have received this communication in error,
please notify us by reply e-mail or telephone and
immediately and permanently delete the message
and any attachments. Thank you
RE: Store long strings in EPICS record. Zelazny, Michael Stanley
Store long strings in EPICS record. Ganesh Jangir
RE: Store long strings in EPICS record. Mark Rivers
Prev: Re: Store long strings in EPICS record. Ralph Lange
Next: Re: Trouble with caget with denSnmp John A. Priller
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Next: RE: Store long strings in EPICS record. Zelazny, Michael Stanley
ANJ, 17 Dec 2015 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
