1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: Trouble with caget with denSnmp
To: <[email protected]>
Date: Tue, 25 Feb 2014 10:25:36 -0500
If you could post (or email me) the record definition I can take a look at it.  The results of an snmpwalk of the device would also be useful in troubleshooting.
It doesn't look like an error the driver is printing, there's no "did not find" error in my code anyway, so I suspect it's something from the NetSNMP libraries.  If those can't parse your MIB files the driver won't be able to request the right data element from the device, and that could explain why you get read errors.
On 2/25/2014 9:53 AM, Nicoletta Petrella wrote:
Dear All,
I'm still a new user of EPICS, I wrote a simple IOC to get temperature values from the TCW122B-CM module.
The module is SNMP manageable so I used devSnmp from nscl labs as a support device for EPICS.
When I run the IOC, I get the message
"Did not find 'MacAddress' in module RFC1155-SMI"
and the IOC starts anyway. When I use the command caget on the temperature PV I get always 0.
caget TCW122B:Temp1
TCW122B:Temp1                  0
With camonitor, I get
camonitor TCW122B:Temp1
TCW122B:Temp1                  2014-02-25 14:36:17.094394 0 READ INVALID
If I use snnmpget, I get the real temperature value.
Any help to understand why I always get 0 from caget?
Thank you very much.
Nicoletta
..0==/--\==0....
....../___\........
......_| |_.........
Prev: RE: Store long strings in EPICS record. Mark Rivers
Next: Re: Error in building epics base-3.15.0.1 on windows XP (32 bit) using mingw Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Trouble with caget with denSnmp Nicoletta Petrella
Next: Re: Trouble with caget with denSnmp Nicoletta Petrella
ANJ, 17 Dec 2015 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
