1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: RE: Increasing scan rate to 10 kHz
To: Evgeniy <[email protected]>, EPICS mailing list <[email protected]>
Date: Tue, 26 Nov 2013 17:00:09 -0800
You need hardware with proper clock and in particular a hardware circular buffer which you populate with your samples.
Software wise, you read the hardware buffer at a much lower frequency, but fast enough so it doesn't wrap around.
(i.e. set the size of the hardware buffer correctly and use 2 pointers (last data written, last data read))
Read all the new data from the hardware buffer **at once** and append it to your compress record.
What are you sampling and how do you currently intend to do it?
can you lose chunks of data?
Good luck!
Emmanuel
> Date: Tue, 26 Nov 2013 15:20:22 -0800
> From: [email protected]
> To: [email protected]
> Subject: Increasing scan rate to 10 kHz
> Hello,
> I can easily set scan period to 0.01 second by adding:
> choice(menuScan_01_second,".01 second")
> in dbd file.
> What about adding scan period 0.0001 second?
> Similar line:
> choice(menuScan_0001_second,".0001 second")
> doesn't work.
> CLOCKS_PER_SECOND on my 8-core DELL server is 1000000 (running SL5.4).
> What should I do to set scan period to 0.0001 second?
> I need such short period to quickly fill in the circular buffer of
> compress record.
> Thanks,
> Evgeniy
Increasing scan rate to 10 kHz Evgeniy
Prev: Re: Increasing scan rate to 10 kHz Andrew Johnson
Next: Re: EPICS on RTEMS 4.11 Till Straumann
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: Increasing scan rate to 10 kHz Benjamin Franksen
Next: Error with Asyn and rpcgen Lucas Jose Monteiro Carvalho
ANJ, 20 Apr 2015 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
