1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: EPICS on RTEMS 4.11
To: Nadia Gruman <[email protected]>, "[email protected]" <[email protected]>
Date: Wed, 27 Nov 2013 08:45:45 +0100
Nadia.
If you seek help then I suggest you provide as much information
about your situation as possible along with your request.
"I have a problem, please help"
does not give us any clue as to what exactly you were trying to do
and what exactly went wrong. Chances to get a reply increase
if you give more details. At the least, I recommend to attach a
***complete*** log of your failed attempt to build.
Please don't make the common mistake to just copy/paste the
few lines where the actual failure happens. It is very important that
you provide a complete log because in many cases the cause
for the failure can be determined from information that is contained
somewhere in the log (but not in the excerpt which the novice
solely believes to be relevant).
Good luck
- Till
On 11/27/2013 12:19 AM, Nadia Gruman wrote:
Hello all,
Is anyone using EPICS with RTEMS 4.11? I am trying to build it for use with MVME5500, but I'm running into some issues and wondering if I should use 4.10.
There are compilation issues I ran into on Linux 12.04, plus there seem to be no rtems addon packages for 4.11 on their git site.
Thank you,
Nadia Gruman
Re: EPICS on RTEMS 4.11 Kate Feng
EPICS on RTEMS 4.11 Nadia Gruman
Prev: RE: Increasing scan rate to 10 kHz Emmanuel Mayssat
Next: RE: EpicsSharp issues Bertrand Alain Gregor
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: EPICS on RTEMS 4.11 Nadia Gruman
Next: Re: EPICS on RTEMS 4.11 Kate Feng
ANJ, 20 Apr 2015 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
