Breakpoint tables should be considered a basic feature of any control system, including EPICS.
I would like to make a petition to have the breakpoint table implementation reviewed.
My suggestions:
1/ RVAL in should be double (at least for ai/ao and maybe for all records)
2/ no check on monotonicity in X and Y.
* Just properly document side effects in manual. (Happy to take care of that!)
* Whoever create the table and associated records should know what she/he is doing
Comments?
PS: Bob, I wouldn't mind contributing to the documentation.
Except most of the documentation is formatted as PDF documents or read-only html pages.
Emmanuel
> From:
[email protected]> To:
[email protected];
[email protected];
[email protected]> Subject: RE: Breakpoint tables: Raw value must be integer?!?
> Date: Mon, 25 Nov 2013 14:15:49 +0000
> I've taken the cheap way out -- instead of using Ampere for my current-to-field records, I use milliAmp integer values.
> So instead of a 'sub' or 'aSub', I have to deal with one 'ai' and one trivial 'calc' record.
> It's marginally simpler this way.
> Cheers -Mathias
> -----Original Message-----
> From:
[email protected] [mailto:
[email protected]] On Behalf Of Allison, Stephanie
> Sent: Friday, November 22, 2013 8:08 PM
> To: 'Emmanuel Mayssat';
> Hi Emmanuel,
> > Is RVAL supposed to be an integer?
> Yes.
> > How can fix my current example?
> I'm sure other people have a better solution but I use a subroutine record. The logic looks something like this (I snipped code that you don't care about so maybe it doesn't compile):
