1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Breakpoint tables: Raw value must be integer?!?
Date: Fri, 22 Nov 2013 16:49:15 -0800
I would like to replace a few of my existing CALC records (polynomial transformation) with simple breakpoint tables.
Let's assume that my raw values are voltages between 0 and 5V, I could therefore build a transformation table as follow:
breaktable(bptPosSlope) {
        raw=0.000000 slope=9.000000e+00 eng=-27.000000
        raw=1.000000 slope=1.800000e+01 eng=-18.000000
        raw=2.000000 slope=1.800000e+01 eng=0.000000
        raw=3.000000 slope=1.400000e+01 eng=18.000000
        raw=4.000000 slope=3.000000e+00 eng=32.000000
        raw=5.000000 slope=3.000000e+00 eng=35.000000
Although the table allows for double/float transformation, to my surprise, the RAW value stored in the AI record is an integer.
Maybe is it because of my INP link...
This record is supposed to be the raw value
clsXdev:6175>dbpr RECORDS:BrkpntTable:Rdbck:RawAI
ASG:                DESC: Raw readback  DISA: 0             DISP: 0
DISV: 1             NAME: RECORDS:BrkpntTable:Rdbck:RawAI   RVAL: 0
SEVR: NO_ALARM      STAT: NO_ALARM      SVAL: 0             TPRO: 0
VAL: 1.111
Which is transformed in another ai record (which has its INP field pointing to the above record).
clsXdev:6175>dbpr RECORDS:BrkpntTable:RdbckAI 3
ACKS: NO_ALARM      ACKT: YES           ADEL: 0             ALST: -18
AOFF: 0             ASG:                ASLO: 1             BKPT: 00
DESC: Readback      DISA: 0             DISP: 0             DISS: NO_ALARM
DISV: 1             DTYP: Raw Soft Channel                  EGU: mm
EGUF: 0             EGUL: 0             EOFF: 0             ESLO: 1
EVNT: 0             FLNK:CONSTANT 0     HHSV: NO_ALARM      HIGH: 0
HIHI: 0             HOPR: 0             HSV: NO_ALARM       HYST: 0
INIT: 0             INP:DB_LINK RECORDS:BrkpntTable:Rdbck:RawAI.VAL NPP NMS
LALM: -18           LBRK: 0             LCNT: 0             LINR: bptPosSlope
LLSV: NO_ALARM      LOLO: 0             LOPR: 0             LOW: 0
LSV: NO_ALARM       MDEL: 0             MLST: -18
NAME: RECORDS:BrkpntTable:RdbckAI       NSEV: NO_ALARM      NSTA: NO_ALARM
ORAW: 1             PACT: 0             PHAS: 0             PINI: NO
PREC: 3             PRIO: LOW           PROC: 0             PUTF: 0
ROFF: 0             RPRO: 0             RVAL: 1             SCAN: 1 second
SDIS:CONSTANT       SEVR: NO_ALARM      SIML:CONSTANT       SIMM: NO
SIMS: NO_ALARM      SIOL:CONSTANT       SMOO: 0             STAT: NO_ALARM
SVAL: 0             TIME: 2013-11-22 16:44:26.374133281     TPRO: 0
TSE: 0              TSEL:CONSTANT       UDF: 0              VAL: -18
Now for some reason the RVAL of this last record is = to 1 (and not 1.1111)
As a result, the VAL is not calculated correctly.
Is RVAL supposed to be an integer?
How can fix my current example?
Emmanuel
RE: Breakpoint tables: Raw value must be integer?!? Allison, Stephanie
Prev: Re: Why should I care about breakpoint table monotonicity? Andrew Johnson
Next: RE: Breakpoint tables: Raw value must be integer?!? Allison, Stephanie
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: EpicsSharp issues Alain Bertrand
ANJ, 20 Apr 2015 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
