1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Motor field "UEIP" cause
To: <[email protected]>
Date: Sat, 31 Aug 2013 17:02:45 +0800
Dear all,
I have a similar behavior as the thread http://www.aps.anl.gov/epics/tech-talk/2010/msg00906.php which posted at 2010. But it occurs when I change the field UEIP anytime. At first, I wrote the UEIP in the motor template, the message “drvMAXv.cc:motorIsr: command error ? card 00” will cause the ioc initialize failed. After remove the field in the db field, the ioc can be loaded successfully and running without problem. But I have encoder, so when I set UEIP to Yes or No, the message come out in console, while the ioc do not crash, and the encoder works also.
By the way, I also saw the timing problem when ioc boot, I got the message like "***MAXv card #Disabled*** Watchdog Timeout CTR ="
The controller is a mvme5500 running with vxworks, Tornado 2.6. The version of motor is 6-7-1. Any suggestion to remove these messages is appreciated.
Best Regards,
Qisheng
Re: Motor field "UEIP" cause Ron Sluiter
Prev: WSU Position at APS Graber, Tim
Next: Vacancy at Diamond Light Source for Accelerator Control Systems Leader mark.heron
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Next: Re: Motor field "UEIP" cause Ron Sluiter
ANJ, 20 Apr 2015 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
