1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: RE: asyn+streamDevice hangs with synchronousLock:Yes
To: "'J. Lewis Muir'" <[email protected]>
Date: Mon, 15 Jul 2013 14:53:38 +0000
Hi Lewis,
This problem did get resolved.
There were 2 problems.  Both have to do with the way that StreamDevice handles I/O Intr scanned records, which is by polling.
1) Brian had set the noProcessEos flag to 1 on his drvAsynIPPort driver, so it was not using the EOS interpose interface.  Since his device does not send an EOS character this seemed a reasonable thing to do.  But I found that the problem of hanging went away if noProcessEos was set to 0.  I don't completely understand this yet, but the EOS interpose layer does add another level of buffering.
2) Even with noProcessEos=0 my tests showed that not all messages from the device were resulting in record processing, some messages were missed.  This was basically an interplay of two things:
  - The device does not send a terminator and does not have a fixed message size, so the only way to detect the end of a message is by a timeout.
  - The default polling rate of StreamDevice for an I/O Intr scanned record is the timeout, which defaults to 1.0 second.  However, the PollPeriod parameter can be used to set it to another value.
I found that if I set PollPeriod = 100 ms, and I set noProcessEos=0 then my simulation driver worked fine (i.e. the I/O Intr scanned record processed for each message) with message periods of 0.1, 0.2, 0.5, 1.0, and 2.0 seconds.
So there appears to be a solution to the problem.
-----Original Message-----
Sent: Monday, July 15, 2013 9:27 AM
To: Mark Rivers
Subject: Re: asyn+streamDevice hangs with synchronousLock:Yes
On 7/8/13 6:51 PM, Mark Rivers wrote:
> This should be relatively easy to track down now that we can reproduce it with a simple dummy server.
> I'll look at it tomorrow.
> Mark
Hi, Mark.
I'm curious; did this ever get solved?  No worries if not, but since I
was following the thread, I'm interested to know what the problem was.
Lewis
RE: asyn+streamDevice hangs with synchronousLock:Yes Mark Rivers
Re: asyn+streamDevice hangs with synchronousLock:Yes Brian McAllister
Prev: Re: Looking for STRUCK SIS3302 device driver Michael Davidsaver
Next: single IOC on Linux with two ports Hovanes Egiyan
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: RE: asyn+streamDevice hangs with synchronousLock:Yes Mark Rivers
Next: naming services Silver
ANJ, 20 Apr 2015 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
