Dear Matej, Thanks for the reply.
As you mention a tried iptables --flush , Then I re run the program but the error remains same. That is : Acquisition of greeting was not successful, failed to connect: ChannelRPC never connected.
Snap of command prompt is as follows [prasad@01HW341662 helloWorld]$ ./helloServerRunner
pvAccess Server v1.2-SNAPSHOT CLASS : org.epics.pvaccess.server.impl.remote.ServerContextImpl
VERSION : pvAccess Server v1.2-SNAPSHOT CHANNEL PROVIDER : rpcService BEACON_ADDR_LIST :
AUTO_BEACON_ADDR_LIST : true BEACON_PERIOD : 15.0 BROADCAST_PORT : 5076
SERVER_PORT : 5075 RCV_BUFFER_SIZE : 16384 IGNORE_ADDR_LIST:
STATE : INITIALIZED ^C[prasad@01HW341662 helloWorld]./helloClientRunner Stefania
Acquisition of greeting was not successful, failed to connect: ChannelRPC never connected. [prasad@01HW341662 helloWorld]$
Kindly help me. Thank you Ganesh
-----Forwarded by Ganesh Jangir/MUM/TCS on 07/01/2013 01:57PM -----
From: "Matej Sekoranja" <[email protected]> To: "Andrew Johnson" <[email protected]> Cc: "PVData Developers" <[email protected]>, "Ganesh Jangir/PNE/TCS" <[email protected]> Sent: Friday, June 21, 2013 8:48:21 PM Subject: Re: EPICSv4 gettingStarted
Some installations have firewalls (iptables) configured so that they do not allow UDP broadcasts/search. Just for sake of a quick test, do (as root)
iptables --flush
and try then.
Matej On Fri, Jun 21, 2013 at 5:00 PM, Andrew Johnson <[email protected]> wrote:
I'm forwarding this message to the V4 list rather than the tech-talk list
address because I don't know whether you guys are all subscribed there and
this question needs a Java expert to answer.
Ganesh, if you want to email tech-talk the real list address is tech-talk@
not tech-talk-bounces@ — the later is an internal address used by the mailman
software to detect undeliverable messages. Please correct your address book
entry.
- Andrew
Advertising may be described as the science of arresting the human
intelligence long enough to get money from it. -- Stephen Leacock
---------- Forwarded message ---------- From: Ganesh Jangir/PNE/TCS <[email protected]> To: tech-talk-bounces EPICS <[email protected]>
Cc: Date: Fri, 21 Jun 2013 18:38:54 +0530 (IST) Subject: EPICSv4 gettingStarted Hello All, I am trying to install EPICSv4-Java-2.0-BETA by following the steps at http://epics-pvdata.sourceforge.net/gettingStarted.htmlBut is could not locate the directory for step no. 4.1 : EPICSv4-Java-2.0-BETA/common/source/pvCommon_setup.bash How to proceed this step?? 4. Modify helloWorld_setup.bash
- Set your location of pvCommon_setup.bash, e.g.:
source $HOME/Development/epicsV4/releasetest/EPICSv4-Java-2.0-BETA/common/source/pvCommon_setup.bas
Also I able to install the setup by escaping this step. but got and error during running the last step no. 7. :
Acquisition of greeting was not successful, failed to connect: ChannelRPC never connected.Snap of command prompt is as follows[prasad@01HW341662 helloWorld]$ ./helloServerRunner
pvAccess Server v1.2-SNAPSHOTCLASS : org.epics.pvaccess.server.impl.remote.ServerContextImpl
VERSION : pvAccess Server v1.2-SNAPSHOTCHANNEL PROVIDER : rpcServiceBEACON_ADDR_LIST :
AUTO_BEACON_ADDR_LIST : trueBEACON_PERIOD : 15.0BROADCAST_PORT : 5076
SERVER_PORT : 5075RCV_BUFFER_SIZE : 16384IGNORE_ADDR_LIST:
STATE : INITIALIZED^C[prasad@01HW341662 helloWorld]./helloClientRunner Stefania
Acquisition of greeting was not successful, failed to connect: ChannelRPC never connected.[prasad@01HW341662 helloWorld]$ Kindly help me here.
I am feeling these steps at ( http://epics-pvdata.sourceforge.net/gettingStarted.html) are not updated for this version. But I am not sure. Thank you Regards Ganesh =====-----=====-----=====
Notice: The information contained in this e-mail
message and/or attachments to it may contain
confidential or privileged information. If you are
not the intended recipient, any dissemination, use,
review, distribution, printing or copying of the
information contained in this e-mail message
and/or attachments to it are strictly prohibited. If
you have received this communication in error,
please notify us by reply e-mail or telephone and
immediately and permanently delete the message
and any attachments. Thank you
This SF.net email is sponsored by Windows:
Build for Windows Store.
http://p.sf.net/sfu/windows-dev2dev
- Re: ChanneIRPC never connected White, Greg
Re: registerRecordDevice... crashes IOC during startup Dirk Zimoch
Re: Updating the RDB archiver at the STAR experiment Kasemir, Kay
<2013>
Support for Amp Tek X-123 David Reid
<2013>
ANJ, 20 Apr 2015 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
EPICS V4
IRMIS
Talk
Bugs
Documents
Links
Licensing
