Gangesh,
You may check the document "Troubleshooting EPICS V4" [1] for help. That document
attempts to predict some potential problems a user might have, and offer guidelines
for avoidance. It includes a number of possible causes of "client can't connect to server".
There is a 5th cause not listed too: I think pvAccess of beta 2.0 required at least 1 networking
interface to be set up (that's right isn't it *Matej*?). That means, for instance,
running your server and client on the same host, where that host is not connected to any
network (like you're working on a laptop on a plane without wifi), results in failure
to connect.
Please let us know on <[email protected]<mailto:[email protected]>> if you still have issues.
Cheers
Greg
[1] http://epics-pvdata.sourceforge.net/troubleshooting.html
On Jul 1, 2013, at 1:25 AM, Ganesh Jangir <[email protected]<mailto:[email protected]>> wrote:
Dear Matej,
Thanks for the reply.
As you mention a tried iptables --flush , Then I re run the program but the error remains same.
That is :
Acquisition of greeting was not successful, failed to connect: ChannelRPC never connected.
Snap of command prompt is as follows
[prasad@01HW341662 helloWorld]$ ./helloServerRunner
pvAccess Server v1.2-SNAPSHOT
CLASS : org.epics.pvaccess.server.impl.remote.ServerContextImpl
VERSION : pvAccess Server v1.2-SNAPSHOT
CHANNEL PROVIDER : rpcService
BEACON_ADDR_LIST :
AUTO_BEACON_ADDR_LIST : true
BEACON_PERIOD : 15.0
BROADCAST_PORT : 5076
SERVER_PORT : 5075
RCV_BUFFER_SIZE : 16384
IGNORE_ADDR_LIST:
STATE : INITIALIZED
^C[prasad@01HW341662 helloWorld]./helloClientRunner Stefania
Kindly help me.
Thank you
Ganesh
-----Forwarded by Ganesh Jangir/MUM/TCS on 07/01/2013 01:57PM -----
From: "Matej Sekoranja" <[email protected]<mailto:[email protected]>>
To: "Andrew Johnson" <[email protected]<mailto:[email protected]>>
Cc: "PVData Developers" <[email protected]<mailto:[email protected]>>, "Ganesh Jangir/PNE/TCS" <[email protected]<mailto:[email protected]>>
Sent: Friday, June 21, 2013 8:48:21 PM
Subject: Re: EPICSv4 gettingStarted
Some installations have firewalls (iptables) configured so that they do not allow UDP broadcasts/search.
Just for sake of a quick test, do (as root)
iptables --flush
and try then.
Matej
On Fri, Jun 21, 2013 at 5:00 PM, Andrew Johnson <[email protected]<mailto:[email protected]>> wrote:
I'm forwarding this message to the V4 list rather than the tech-talk list
address because I don't know whether you guys are all subscribed there and
this question needs a Java expert to answer.
Ganesh, if you want to email tech-talk the real list address is tech-talk@
not tech-talk-bounces@ — the later is an internal address used by the mailman
software to detect undeliverable messages. Please correct your address book
entry.
- Andrew
Advertising may be described as the science of arresting the human
intelligence long enough to get money from it. -- Stephen Leacock
---------- Forwarded message ----------
From: Ganesh Jangir/PNE/TCS <[email protected]<mailto:[email protected]>>
To: tech-talk-bounces EPICS <[email protected]<mailto:[email protected]>>
Cc:
Date: Fri, 21 Jun 2013 18:38:54 +0530 (IST)
Subject: EPICSv4 gettingStarted
Hello All,
I am trying to install EPICSv4-Java-2.0-BETA by following the steps at http://epics-pvdata.sourceforge.net/gettingStarted.html
But is could not locate the directory for step no. 4.1 : EPICSv4-Java-2.0-BETA/common/source/pvCommon_setup.bash
How to proceed this step??
4. Modify helloWorld_setup.bash
1. Set your location of pvCommon_setup.bash, e.g.: source $HOME/Development/epicsV4/releasetest/EPICSv4-Java-2.0-BETA/common/source/pvCommon_setup.bas
Also I able to install the setup by escaping this step. but got and error during running the last step no. 7. :
BEACON_ADDR_LIST :
SERVER_PORT : 5075
IGNORE_ADDR_LIST:
STATE : INITIALIZED
Kindly help me here.
I am feeling these steps at (http://epics-pvdata.sourceforge.net/gettingStarted.html) are not updated for this version. But I am not sure.
Thank you
Regards
Ganesh
Notice: The information contained in this e-mail
message and/or attachments to it may contain
confidential or privileged information. If you are
not the intended recipient, any dissemination, use,
review, distribution, printing or copying of the
information contained in this e-mail message
and/or attachments to it are strictly prohibited. If
you have received this communication in error,
please notify us by reply e-mail or telephone and
immediately and permanently delete the message
and any attachments. Thank you
This SF.net<http://SF.net> email is sponsored by Windows:
Build for Windows Store.
http://p.sf.net/sfu/windows-dev2dev
- ChanneIRPC never connected Ganesh Jangir
Re: querying for sets of pvs in archived data pthomas
RE: asyn+streamDevice hangs with synchronousLock:Yes Mark Rivers
<2013>
asyn+streamDevice hangs with synchronousLock:Yes Brian McAllister
<2013>
