Hi -
In addition to the bus name in drvAsynIPPortConfigure not matching the one in your database, I wonder if your STREAM_PROTOCOL_PATH is correct. Is your ioc called "soft-iocps" and does the protocol file reside in that directory?
> I got this IOC after it had been compiled on another machine
Did you recompile it on the machine you are using now (linux-x86)? Are you using RHEL6 32 bit or something else?
Stephanie
> -----Original Message-----
> From: [email protected] [mailto:[email protected]] On Behalf
> Of James F Ross
> Sent: Monday, April 22, 2013 8:21 AM
> To: Mark Rivers
> Cc: EPICS Tech Talk
> Subject: Re: genesys power supply IOC
> I believe it uses TCP (it communicates via an ethernet connection). Below is my start up
> script. I got this IOC after it had been compiled on another machine, so it is quite possible
> I missed changing something.
> #!../../bin/linux-x86/genesys
> cd ../..
> dbLoadDatabase("dbd/genesys.dbd")
> genesys_registerRecordDeviceDriver(pdbbase)
> ## Location of stream protocol files
> epicsEnvSet "STREAM_PROTOCOL_PATH", "iocBoot/soft-iocps/"
> dbLoadRecords("db/genesysPSAll.db")
> drvAsynIPPortConfigure("GEN8-180-88Z", "130.199.60.184:8003",0,0,0)
> iocInit()
> # Start sequences
> seq(&psControl,"ps=GEN8-180-88Z")
> I know the IP is right for the drvAsynIPPortConfigure, but I don't know if 8003 is correct.
> Thank you
> James
> On Mon, Apr 22, 2013 at 11:05 AM, Mark Rivers <[email protected]> wrote:
> Can you explain the interface to the power supply? It is serial, TCP, etc.
> How have you configured the asyn port?
> Can you send your startup script?
> Mark
> ________________________________
> From: [email protected] [[email protected]] on behalf
> of James F Ross [[email protected]]
> Sent: Monday, April 22, 2013 9:45 AM
> To: EPICS Tech Talk
> Subject: genesys power supply IOC
> Hello all,
> I'm trying to set up an IOC for a genesys power supply. It compiles, but when I try
> to run st.cmd I get the following errors (showing up in red after iocInit):
> 2013/04/22 09:37:58.974089 _main_ Businterface '07G-ECD-BL08' not found for
> '07G-ECD-BL08:Curr'
> 2013/04/22 09:37:58.974603 _main_ 07G-ECD-BL08:Curr: Can't attach to bus
> 07G-ECD-BL08 -1
> 2013/04/22 09:37:58.974715 _main_ 07G-ECD-BL08:Curr: Record initialization
> failed
> Segmentation fault
> I'm using asyn version 4.21, StreamDevice version 2.6, epics 3.14.12.1, and
> sequencer 2.0.12.
> From what I've been able to find, this seems to be a problem between
> StreamDevice and asyn. I originally had aysn 4.13 before getting 4.21 and trying that.
> Neither solved the issue though. Anyone have any experience with this kind of issue?
> Thanks!
> James
- Re: genesys power supply IOC James F Ross
- genesys power supply IOC James F Ross
- RE: genesys power supply IOC Mark Rivers
<2013>
<2013>
