Yes, the ioc is soft-iocps and genesys.proto is there along with st.cmd. Changing the db file from "07G-ECD-BL08" to "GEN8-180-88Z" seems to have solved those errors. Right now when I try to run it I get some port connect errors: "2013/04/22 11:50:37.911 Can't connect to 130.199.60.184:8003: No route to host GEN8-180-88Z -1 autoConnect could not connect" as well as various variable related errors:
"2013/04/22 11:52:57.158945 scan0.5 GEN8-180-88Z:State lockRequest: pasynManager->queueRequest() failed: port GEN8-180-88Z not connected" However, I think this is a problem with the power supply itself not being connected as I can't ping it right now. I'll look into why it isn't connected unless someone knows what else might cause this error (they were installed recently and might have been left disconnected after last access). Thanks all James On Mon, Apr 22, 2013 at 11:43 AM, Allison, Stephanie <[email protected]> wrote: Hi -
ANJ, 20 Apr 2015 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
