Can this value be increased in the source instead and be available in the next release (whenever that is)?
Applying a patch as simple as this requires
- create the patch
- modify the autosave installation script to apply patches
- document the change
- inform QA
- inform coworkers
when 6 months later, you have machine operations issue and you realize that
- a rogue IOC
- installed by an intern
- who did not read the documentation
- did a manual install and was unaware of the patch
- ... <insert worse case scenario here>... including downtime and hardware damage ;-)
Could you please increase the value of MAXRESTOREFILES (or implement a chained list) in the next version of autosave?
Emmanuel
> There's no real reason autosave is limited to 8 files, other than that I
> didn't know anyone wanted more than that. I haven't tested large numbers
> of files, but you can edit save_restore.h and change
> #define MAXRESTOREFILES 8
> to whatever you want. The number of save files is already unlimited (you
> can make as many create_monitor_set() calls as you want.)
> Yes, the number of restore files could be made unlimited. That's what I
> meant to imply when I said that the list of restore file names could be
> implemented as a linked list. If someone wants 1000 files, then a linked
> list is probably called for. If 30 is enough, then
> #define MAXRESTOREFILES 30
> seems adequate. All we're doing is allocating an array of pointers.
> Tim
> Tim Mooney (
[email protected]) (630)252-5417
> Software Services Group (www.aps.anl.gov)
> Advanced Photon Source, Argonne National Lab
